Skip to content
v.fixed.segmentpoints
segment points along a vector line with fixed distances
v.fixed.segmentpoints vector=name cat=integer dir=name prefix=prefix [distance=integer] [--verbose] [--quiet] [--qq] [--ui]
Example:
v.fixed.segmentpoints vector=name cat=0 dir=name prefix=prefix
grass.tools.Tools.v_fixed_segmentpoints(vector, cat, dir, prefix, distance=100, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.v_fixed_segmentpoints(vector="name", cat=0, dir="name", prefix="prefix")
grass.script.run_command("v.fixed.segmentpoints", vector, cat, dir, prefix, distance=100, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("v.fixed.segmentpoints", vector="name", cat=0, dir="name", prefix="prefix")
Parameters
vector=name [required]
    Name of input vector map
    Or data source for direct OGR access
cat=integer [required]
    Category of a vector line
dir=name [required]
    Directory where the output will be found
prefix=prefix [required]
    output prefix (must start with a letter)
distance=integer
    fixed distance between segment points
    Default: 100
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
vector : str, required
    Used as: input, vector, name
cat : int, required
    Used as: input, cats
dir : str, required
    Used as: input, dir, name
prefix : str, required
    Used as: prefix
distance : int, optional
    Used as: integer
    Default: 100
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
Returns:
Raises:
cat : int, required
dir : str, required
    Used as: prefix
    Used as: integer
    Default: 100
    Default: None
    Quiet module output
    Default: None
    Default: None
DESCRIPTION
v.fixed.segmentpoints creates segment points along a vector line with fixed distances by using the v.segment module. A category of one line has to be given. Start and end point of the line will be considered. The distance option is limited to an integer number. As a prefix (starting with a letter) has to be given, resulting vectors are prefix_singleline and prefix_segmentpoints, resulting external files are prefix_segmentpoints and prefix_segmentpoints.csv.
The next to last point may be closer to the last point as the given distance. Distance information for every point is added to the vector attribute table. The attribute is then exported as CSV file. The category (cat) of the input line is stored in the column cat_line of the prefix_segmentpoints attribute table.
EXAMPLE
  # NC sample data set
  v.fixed.segmentpoints vector=streams@PERMANENT cat=40102 dir=C:\tmp distance=25
DEPENDENCIES
  • v.segment
SEE ALSO
v.segment
AUTHOR
Helmut Kudrnovsky
