grassdata in their home directory.
In multi-user environment users often have a grassdata directory
mounted as a network directory (network file system).
For teams, a centralized GRASS DATABASE would be defined
in a shared network file system (e.g. NFS).
GRASS Databases can be safely copied or moved as any other directories. Don't be confused with (relational) databases which are used in GRASS to hold attribute data and might be part of the GRASS Database. From user point of view, GRASS Database with all its data in it is similar to, e.g. PostGIS, database, as it stores all information inside in a specific format and is accessible by specific tools. GRASS Databases is in GRASS often called GISDBASE or DATABASE.
GRASS projects can be safely copied or moved as any other directories. Compressed projects are usually what GRASS users exchange between each other when they want to share a lot of data. For example, GRASS sample data are provided as projects.
Note that a GRASS project used to be called location and this name has not been completely removed from code and documentation yet.
Users and programmers familiar with relational databases such as PostgreSQL can view projects as individual databases inside a storage area (the GRASS Database). Mapsets in a project are like namespaces or schemas inside a database.
GRASS is always connected to one particular mapset.
GRASS modules can create, modify, change, or delete a data only in
the current mapset.
By default, only the data from the current mapset and PERMANENT mapset
are visible. Using
g.mapsets
module or in GUI other mapsets can be made visible and seamlessly accessible.
All data are available for reading when mapset is specified explicitly,
for example to access map streets in mapset
new_highway user can use streets@new_highway.
For maps which are in the current or PERMAENT mapsets or mapsets
sets as visible (accessible), there is no need to use
@mapset syntax.
Mapsets are used to store maps related to one project, smaller project, specific task, issue or subregions. In a multi-user environment, where team members work together on a single project, individual mapsets support simultaneous access of several users to the maps stored within the same project. Besides access to their own mapset, each user can also read maps in PERMANENT Mapsent and in other users' mapsets when set. However, each user can modify or remove only the maps in his or her own mapset.
Besides the geospatial data, mapset holds additional data such as
color tables (managed e.g. by r.colors)
and the current computational region's extent and resolution
stored in a file called WIND
and managed by g.region.
Mapsets can be copied and moved as directories only when it is clear that their coordinate reference systems (as reported by g.proj) match. In case of data coming with different coordinate reference systems, it is recommended to use r.proj or v.proj to reproject the data. The files and directories should not be moved or modified directly, but only using GRASS tools.
Since the maps in PERMANENT mapset are visible from all the other mapsets, it can be used to store the base maps (base cartography), data common to all projects or needed for different analyses done is separate mapsets.
In multi-user environment, data in the PERMANENT mapset can only be added, modified or removed by the owner of the PERMANENT mapset; however, they can be accessed, analyzed, and copied into their own mapset by the other users. The PERMANENT mapset is useful for providing general spatial data (e.g. an elevation model), accessible but write-protected to all users who are working with the same GRASS project as the database owner. To manipulate or add data to PERMANENT, the owner can start GRASS and choose the relevant project and the PERMANENT mapset.
The PERMANENT mapset also contains the DEFAULT_WIND file which holds
the default computational region's extent and resolution values
for the project (which all mapsets will inherit when they are created).
Users have the option of switching back to the default region at any time.
For cases when import is not desirable, an option to link external data exists. The coordinate reference system of the linked data must match the project's coordinate reference system otherwise the external data cannot be linked. (Linking data in different projection is not allowed as it would require on-the-fly reprojection which could cause inconsistencies in the data.
For example, module r.external links external raster data, so that the data are accessible in GRASS Database as standard raster maps. Similarly for newly created maps, r.external.out setups a format and directory where the actual data will be stored, however in GRASS Database the data will be created as standard maps.
world_latlong_wgs84.
From there a new project can be created.
# Linux, Mac, *BSD, ...: grass --text ~/grassdata/nc_spm_08_grass7/user1 # Windows grass --text D:\grassdata\nc_spm_08_grass7\user1
# Linux, Mac, *BSD, ...: grass -c EPSG:5514:3 ~/grassdata/myproject # Windows grass -c EPSG:5514:3 D:\grassdata\myproject
The most convenient way of using the Project Wizard is creating new project based on a georeferenced file, such as Shapefile or GeoTIFF, or by selecting the corresponding EPSG code of the coordinate reference system. In case of using georeferenced file, you are asked whether the data itself should be imported into the new project. The default region is then set to match imported map.
If data were already imported, you can add them into the Layer Manager now and display them. More data can be imported into the project, e.g. using import options in the File menu in Layer Manager or r.import.
Available at: GRASS Database source code (history)
Latest change: Monday Jul 13 12:40:56 2026 in commit: 82d0026fa08ab95f543625be64968f339f78fdc7
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2026 GRASS Development Team, GRASS 8.5.1dev Reference Manual
