v.surf.rst.cv
Performs a cross-validation procedure to optimize the parameterization of v.surf.rst.
v.surf.rst.cv [-t] point_cloud=name [mask=name] [tension=float [,float,...]] [smooth=float [,float,...]] [npmin=integer [,integer,...]] [segmax=integer [,integer,...]] [dmin=float [,float,...]] [dmax=float [,float,...]] [theta=float [,float,...]] [scalex=float [,float,...]] [method=string] [levels=integer] [npoints=integer] [seed=integer] [layer=string] [zcolumn=name] [where=sql_query] [zscale=float] [cv_prefix=string] [output_file=name] format=name [nprocs=integer] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
v.surf.rst.cv point_cloud=name format=plain
grass.tools.Tools.v_surf_rst_cv(point_cloud, mask=None, tension=10,20,40,80,160, smooth=0.001,0.01,0.1,1.0,10.0, npmin=None, segmax=None, dmin=None, dmax=None, theta=None, scalex=None, method="grid", levels=3, npoints=None, seed=None, layer="1", zcolumn=None, where=None, zscale=1.0, cv_prefix=None, output_file=None, format="plain", nprocs=0, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.v_surf_rst_cv(point_cloud="name", format="json")
grass.script.parse_command("v.surf.rst.cv", point_cloud, mask=None, tension=10,20,40,80,160, smooth=0.001,0.01,0.1,1.0,10.0, npmin=None, segmax=None, dmin=None, dmax=None, theta=None, scalex=None, method="grid", levels=3, npoints=None, seed=None, layer="1", zcolumn=None, where=None, zscale=1.0, cv_prefix=None, output_file=None, format="plain", nprocs=0, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.parse_command("v.surf.rst.cv", point_cloud="name", format="json")
Parameters
point_cloud=name [required]
Name of the input point vector map
Or data source for direct OGR access
mask=name
Name of the raster map used as mask
Name of input raster map
Tension parameter values to cross-validate
Default: 10,20,40,80,160
Smoothing parameter values to cross-validate
Default: 0.001,0.01,0.1,1.0,10.0
Minimum number of points for approximation in a segment (>segmax)
Multiple values are swept as an outer loop
Maximum number of points in a segment
Minimum distance between points (to remove almost identical points)
Maximum distance between points on isoline (to insert additional points)
Anisotropy angle (in degrees counterclockwise from East)
Anisotropy scaling factor
method=string
Search method over tension and smoothing (grid: full Cartesian product; refine: recursive refinement around the best cell)
Allowed values: grid, refine
Default: grid
levels=integer
Maximum number of refinement levels for method=refine
Default: 3
npoints=integer
Cross-validate on a spatially stratified subsample of approximately this many points
seed=integer
Seed value for the random number generator
Using the same seed ensures identical results, while a randomly generated seed produces different outcomes in each run.
layer=string
Layer number or name
Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name.
Default: 1
zcolumn=name
Name of the attribute column with values to be used for approximation
If not given and input is 2D vector map then category values are used. If input is 3D vector map then z-coordinates are used.
where=sql_query
WHERE conditions of SQL statement without 'where' keyword
Example: elevation < 500 and elevation >= 1
zscale=float
Conversion factor for values used for approximation
Default: 1.0
cv_prefix=string
Prefix to use for cross-validation output maps
Prefix for saved cross-validation error vector maps and interpolated deviation surfaces. If not set, cross-validation maps are temporary.
output_file=name
Output file
Output file for the results in the selected format
format=name [required]
Output format
Allowed values: plain, csv, json
Default: plain
plain: Human readable table
csv: CSV (Comma Separated Values)
json: JSON (JavaScript Object Notation)
nprocs=integer
Default: 0
-t
Use scale dependent tension (recommended when tuning, makes tension transferable across point densities)
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
point_cloud : str, required
Used as: input, vector, name
mask : str | np.ndarray, optional
Used as: input, raster, name
tension : float | list[float] | str, optional
smooth : float | list[float] | str, optional
npmin : int | list[int] | str, optional
segmax : int | list[int] | str, optional
dmin : float | list[float] | str, optional
dmax : float | list[float] | str, optional
theta : float | list[float] | str, optional
scalex : float | list[float] | str, optional
method : str, optional
Default: grid
levels : int, optional
Default: 3
npoints : int, optional
seed : int, optional
layer : str, optional
Used as: input, layer
Default: 1
zcolumn : str, optional
Used as: input, dbcolumn, name
where : str, optional
Used as: input, sql_query, sql_query
zscale : float, optional
Default: 1.0
cv_prefix : str, optional
output_file : str, optional
Output file
Used as: output, file, name
format : str, required
Output format
Used as: name
Default: plain
nprocs : int, optional
Default: 0
flags : str, optional
Allowed values: t
t
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
Returns:
Raises:
mask : str, optional
Default: grid
Default: 3
Default: 1
Default: 1.0
Output file
Output format
Used as: name
Default: plain
Default: 0
Allowed values: t
t
Default: None
Default: None
Quiet module output
Default: None
Default: None
DESCRIPTION
v.surf.rst.cv finds well performing parameters for the regularized spline with tension (RST) interpolation implemented in v.surf.rst by running its leave-one-out cross-validation procedure over combinations of parameter values. For every combination, each input point is withheld in turn, the surface is approximated from the remaining points, and the predictive error (predicted minus observed value) is recorded. The tool summarizes the errors of every combination, reports the best one, and optionally saves the cross-validation error maps. The mask, zcolumn, where, zscale, and layer options are passed through unchanged to every v.surf.rst run.
The tension and smooth options accept lists of values and form the core search space. The remaining RST parameters (npmin, segmax, dmin, dmax, theta, scalex) also accept lists and are swept as an outer loop: every combination of their values is combined with the full tension and smoothing search. See the NOTES for why these parameters need more care when interpreting results.
Two search methods are available:
- method=grid (default) evaluates the full Cartesian product of the tension and smoothing lists.
- method=refine first evaluates the tension x smoothing grid and then recursively refines the search around the best combination: geometric midpoints between the best cell and its neighbors are evaluated, up to levels times or until the error differences within the refinement window become negligible. Use it to locate a finer optimum without enumerating a dense grid. When the best combination lies on the border of the searched range, a warning recommends widening the range.
Parameter combinations are cross-validated in parallel; nprocs controls the number of concurrent runs (each v.surf.rst process runs single threaded). A failing combination is reported as a row with an error instead of stopping the search.
Error metrics
For each combination the tool reports the number of cross-validated points (n), mean error (me, a measure of bias), mean absolute error (mae), root mean square error (rmse), median error, normalized median absolute deviation (nmad), the 68.3rd and 95th percentiles of the absolute error (p68, p95), the extreme errors, and the normalization factor (dnorm, see below). The best combination is selected by RMSE. The best combinations under MAE and NMAD are also reported; when the metrics disagree, the tool warns, because the selection is then driven by a small number of large errors and the residual distribution should be inspected before accepting the result.
The reported cross-validation error of the winning combination is an optimistic estimate of the accuracy of the final surface, because it was selected as the minimum over many candidates. Use an independent set of withheld points to estimate the accuracy of the resulting surface.
Tension, dnorm, and the -t flag
v.surf.rst internally normalizes coordinates by a factor
dnorm = sqrt(area * npmin / n)
where area is the bounding box of the points and n their count. The effective range of the spline is therefore proportional to dnorm/tension: the same tension value acts differently for different point counts, extents, and npmin settings. Consequences:
- A tension optimized for one data set does not transfer to another data set, or even to a subsample of the same data set, unless the -t flag (scale dependent tension) is used. With -t, tension is rescaled by dnorm/1000 and acts on the real coordinates.
- Sweeping npmin together with tension without -t compares different effective tensions across rows; the tool warns in this case.
The computed dnorm is reported for every combination, and with -t the rescaled tension is reported as tension_rescaled. The reported dnorm is derived from the bounding box of the input points and is approximate when the computational region clips part of the input.
Cross-validation on large data sets
Leave-one-out cross-validation is reasonable for up to several thousand points. For larger data sets, set npoints to cross-validate on a spatially stratified random subsample: one point is drawn per cell of a coarse grid sized to yield approximately npoints points, which preserves the spatial coverage of clustered point clouds better than simple random sampling. Use seed for a reproducible selection. Combine subsampling with the -t flag, otherwise the optimal tension found on the subsample does not apply at full point density (the tool warns about this).
Saved cross-validation maps
When cv_prefix is set, the cross-validation error vector map of every
combination is kept as <cv_prefix>_<index> (the cvdev column of the
report gives the map name for each row), the errors are interpolated into
a raster map of the same name, and a diverging color scheme centered on
the median error is applied to both. The error value is stored in the
flt1 attribute column as predicted minus observed.
NOTES
Parameters swept in the outer loop change more than the model fit:
- dmin removes nearly coincident points before interpolation and dmax inserts additional points along lines. Both change which points receive a cross-validation error, so error metrics of rows with different dmin or dmax values are computed over different point sets and are not directly comparable; compare the n column and interpret those rows with care (the tool warns when n differs).
- npmin and segmax control segmentation. For data sets larger than 2 x npmin points, v.surf.rst requires npmin > segmax. To skip segmentation entirely for smaller data sets, set segmax = 2 x npmin.
- theta and scalex (anisotropy) are supported, but the current v.surf.rst evaluates cross-validation errors without applying the anisotropy transformation used in the interpolation, so cross-validation results with anisotropy are unreliable until this is fixed in GRASS; the tool warns when they are used.
The cross-validation procedure works well only for well-sampled phenomena and when minimizing the predictive error is the goal. The parameters found by minimizing the predictive error may not be the best for poorly sampled phenomena (the result could be strongly smoothed with lost details and fluctuations) or when significant noise is present that needs to be smoothed out.
The computational region affects the result: points outside the region receive no cross-validation error and the default dmin is derived from the region resolution. Compare runs only within the same region.
Results are always printed to standard output; output_file writes the
same content to a file in addition. With nprocs greater than one, the
tool runs each combination in a temporary mapset named tmp_cv_* inside
the current project to avoid database contention; these mapsets are
removed when the tool ends, but may remain after a hard interruption and
can then be removed manually.
Possible future extensions include k-fold cross-validation (which would also make dmin/dmax rows comparable), buffered leave-one-out for data with near-duplicate points, and spatially blocked cross-validation for gap-filling applications.
EXAMPLES
Basic grid search
g.region raster=elevation res=30 n=220790 s=218390 w=632680 e=635910 -a
r.random input=elevation npoints=500 seed=0 vector=points -z
v.surf.rst.cv point_cloud=points tension=10,100 smooth=0.5,5.0 \
segmax=600 nprocs=4 format=json output_file=test_cv.json
The JSON output contains one entry per combination and the best combinations per metric:
"input": "points",
"method": "grid",
"scale_dependent_tension": false,
"subsample": null,
"region": {...},
"warnings": [],
"results": [
"tension": 100.0,
"smooth": 0.5,
"segmax": 600,
"cvdev": null,
"n": 500,
"me": 0.005205,
"mae": 2.006109,
"rmse": 2.715355,
"median": -0.224484,
"nmad": 2.269,
"p68": 2.305549,
"p95": 5.610012,
"min": -9.519708,
"max": 9.506766,
"error": null,
"dnorm": 2149.976744
"best": {"rmse": {...}, "mae": {...}, "nmad": {...}}
A report of the best parameter combination is printed to stderr:
Best parameter combination (by RMSE)
Tension: 100
Smoothing: 0.5
segmax: 600
RMSE: 2.71536
MAE: 2.00611
NMAD: 2.269
Refined search
Instead of a dense grid, refine around the best coarse cell:
v.surf.rst.cv point_cloud=points tension=10,40,160 smooth=0.01,0.1,1.0 \
segmax=600 method=refine levels=3 nprocs=4
Sweeping structural parameters
Evaluate the effect of segmentation settings on the optimum, using scale dependent tension so tension values stay comparable across npmin:
v.surf.rst.cv -t point_cloud=points tension=10,40,160 smooth=0.01,0.1,1.0 \
npmin=150,300 segmax=120 nprocs=4
Large data sets
Cross-validate on a spatially stratified subsample of 2000 points:
v.surf.rst.cv -t point_cloud=lidar_points npoints=2000 seed=42 nprocs=8
Saving the error maps
When cv_prefix is set, the error point maps are kept and interpolated into deviation surfaces:
segmax=600 cv_prefix=cvdev nprocs=4
Tension: 100 Smooth: 0.5
Tension: 100 Smooth: 5
Tension: 10 Smooth: 0.5
Tension: 10 Smooth: 5
REFERENCES
- Mitasova, H., Mitas, L. and Harmon, R.S., 2005, Simultaneous spline approximation and topographic analysis for lidar elevation data in open source GIS, IEEE GRSL 2 (4), 375- 379.
- Hofierka, J., 2005, Interpolation of Radioactivity Data Using Regularized Spline with Tension. Applied GIS, Vol. 1, No. 2, pp. 16-01 to 16-13. DOI: 10.2104/ag050016
- Hofierka J., Parajka J., Mitasova H., Mitas L., 2002, Multivariate Interpolation of Precipitation Using Regularized Spline with Tension. Transactions in GIS 6(2), pp. 135-150.
- H. Mitasova, L. Mitas, B.M. Brown, D.P. Gerdes, I. Kosinovsky, 1995, Modeling spatially and temporally distributed phenomena: New methods and tools for GRASS GIS. International Journal of GIS, 9 (4), special issue on Integrating GIS and Environmental modeling, 433-446.
- Mitasova, H. and Mitas, L., 1993: Interpolation by Regularized Spline with Tension: I. Theory and Implementation, Mathematical Geology ,25, 641-655.
- Mitasova, H. and Hofierka, J., 1993: Interpolation by Regularized Spline with Tension: II. Application to Terrain Modeling and Surface Geometry Analysis, Mathematical Geology 25, 657-667.
- Mitas, L., and Mitasova H., 1988, General variational approach to the approximation problem, Computers and Mathematics with Applications, v.16, p. 983-992.
- Neteler, M. and Mitasova, H., 2008, Open Source GIS: A GRASS GIS Approach, 3rd Edition, Springer, New York, 406 pages.
- Talmi, A. and Gilat, G., 1977 : Method for Smooth Approximation of Data, Journal of Computational Physics, 23, p.93-123.
- Wahba, G., 1990, : Spline Models for Observational Data, CNMS-NSF Regional Conference series in applied mathematics, 59, SIAM, Philadelphia, Pennsylvania.
SEE ALSO
r.resamp.rst, v.surf.bspline, v.surf.idw, v.surf.rst, v.vol.rst
AUTHORS
Corey T. White NCSU GeoForAll Lab
SOURCE CODE
Available at: v.surf.rst.cv source code
(history)
Latest change: Saturday Aug 22 18:58:28 2026 in commit 388bb1f
