i.segment.hierarchical
Hierarchical segmentation
i.segment.hierarchical group=name thresholds=float [,float,...] output=name [outputs_prefix=string] [method=string] [similarity=string] [minsizes=integer [,integer,...]] [memory=integer] [iterations=integer] [seeds=name] [bounds=name] [width=integer] [height=integer] [overlap=integer] [processes=integer] [move=string] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
i.segment.hierarchical group=name thresholds=0.02,0.05 output=name
grass.script.run_command("i.segment.hierarchical", group, thresholds=0.02,0.05, output, outputs_prefix="seg__%.2f", method="region_growing", similarity="euclidean", minsizes=None, memory=300, iterations=20, seeds=None, bounds=None, width=None, height=None, overlap=0, processes=None, move=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("i.segment.hierarchical", group="name", thresholds=0.02,0.05, output="name")
grass.tools.Tools.i_segment_hierarchical(group, thresholds=0.02,0.05, output, outputs_prefix="seg__%.2f", method="region_growing", similarity="euclidean", minsizes=None, memory=300, iterations=20, seeds=None, bounds=None, width=None, height=None, overlap=0, processes=None, move=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.i_segment_hierarchical(group="name", thresholds=0.02,0.05, output="name")
Parameters
group=name [required]
Name of input imagery group
thresholds=float [,float,...] [required]
Segment thresholds
Default: 0.02,0.05
output=name [required]
Name of output segment raster map
Name for output raster maps from segment
Default: seg__%.2f
method=string
Segmentation method
Default: region_growing
similarity=string
Similarity calculation method
Default: euclidean
Minimum number of cells in a segment
memory=integer
Memory in MB
Default: 300
iterations=integer
Maximum number of iterations
Default: 20
seeds=name
Name for input raster map with starting seeds
bounds=name
Name of input bounding/constraining raster map
width=integer
Tile width in pixels
height=integer
Tile height in pixels
overlap=integer
Tile overlap in pixels
Default: 0
processes=integer
Number of concurrent processes
move=string
Path where move and copy the mapset
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
group : str, required
Used as: input, group, name
thresholds : float | list[float] | str, required
Segment thresholds
Default: 0.02,0.05
output : str, required
Used as: output, raster, name
outputs_prefix : str, optional
Default: seg__%.2f
method : str, optional
Segmentation method
similarity : str, optional
Default: euclidean
minsizes : int | list[int] | str, optional
memory : int, optional
Memory in MB
Default: 300
iterations : int, optional
Default: 20
seeds : str, optional
Used as: input, raster, name
bounds : str, optional
width : int, optional
height : int, optional
overlap : int, optional
Default: 0
processes : int, optional
move : str, optional
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
Segment thresholds
Default: 0.02,0.05
Default: seg__%.2f
Segmentation method
Default: euclidean
Memory in MB
Default: 300
Default: 20
seeds : str | np.ndarray, optional
bounds : str | np.ndarray, optional
Default: 0
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
i.segment.hierarchical performs a hierarchical segmentation on a image (group). The module uses i.segment.
EXAMPLE
TODO
SEE ALSO
AUTHOR
Pietro Zambelli (University of Trento)
SOURCE CODE
Available at: i.segment.hierarchical source code
(history)
Latest change: Thursday Feb 20 13:02:26 2025 in commit 53de819
