Skip to content
r.colors.contrastbrightness
Change the contrast/brightness of a raster.
r.colors.contrastbrightness input=name output=name minimum=value maximum=value contrast=value brightness=value [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh r.colors.contrastbrightness input=name output=name minimum=0.0 maximum=0.0 contrast=1.0 brightness=0.0
grass.script.run_command("r.colors.contrastbrightness", input, output, minimum, maximum, contrast=1.0, brightness=0.0, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python gs.run_command("r.colors.contrastbrightness", input="name", output="name", minimum=0.0, maximum=0.0, contrast=1.0, brightness=0.0)
grass.tools.Tools.r_colors_contrastbrightness(input, output, minimum, maximum, contrast=1.0, brightness=0.0, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python tools = Tools() tools.r_colors_contrastbrightness(input="name", output="name", minimum=0.0, maximum=0.0, contrast=1.0, brightness=0.0)
Parameters
input=name [required]
    Raster map to change the contrast of.
output=name [required]
    Name for output raster map
minimum=value [required]
    Minimum input/output data value
maximum=value [required]
    Maximum input/output data value
contrast=value [required]
    Contrast (gain, 8bit=>[1.0-3.0]
    Default: 1.0
brightness=value [required]
    Brightness (bias, 8bit=>[0.0-100.0])
    Default: 0.0
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
input : str, required
    Used as: input, raster, name
output : str, required
    Used as: output, raster, name
minimum : float, required
    Used as: value
maximum : float, required
    Used as: value
contrast : float, required
    Used as: value
    Default: 1.0
brightness : float, required
    Used as: value
    Default: 0.0
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
input : str | np.ndarray, required
    Used as: value
    Used as: value
    Used as: value
    Default: 1.0
    Used as: value
    Default: 0.0
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
The r.colors.contrastbrightness module generates a contrasted version of the input raster map. The contrast is the gain of the affine transform, use values of 1.0-3.0 in case of an 8 bit image. The brightness is the bias of the affine transform, use values of 0.0-100.0 in case of an 8 bit image.
EXAMPLES
Contrast enhancement of an 8-bit raster band This does nothing to the image:
sh r.colors.contrastbrightness min=0.0 max=255.0 contrast=1.0 brightness=0.0 input=myinraster output=myoutraster
This does change the contrast of the image:
sh r.colors.contrastbrightness min=0.0 max=255.0 contrast=3.0 brightness=0.0 input=myinraster output=myoutraster
This does change the brightness of the image:
sh r.colors.contrastbrightness min=0.0 max=255.0 contrast=1.0 brightness=100.0 input=myinraster output=myoutraster
SEE ALSO
r.colors, v.colors, r3.colors, r.cpt2grass, r.colors.matplotlib
AUTHOR
Yann Chemin, JRC, Ispra, Italy
SOURCE CODE
Available at: r.colors.contrastbrightness source code (history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
