Skip to content
r.futures.gridvalidation
Module for validating land change simulation on a grid
r.futures.gridvalidation simulated=name reference=name [original=name] [allocation_disagreement=name] [allocation_disagreement_basename=basename] [quantity_disagreement=name] [quantity_disagreement_basename=basename] [kappa=name] [kappasimulation=name] region=name nprocs=integer [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh r.futures.gridvalidation simulated=name reference=name allocation_disagreement=name region=name nprocs=1
grass.script.run_command("r.futures.gridvalidation", simulated, reference, original=None, allocation_disagreement=None, allocation_disagreement_basename=None, quantity_disagreement=None, quantity_disagreement_basename=None, kappa=None, kappasimulation=None, region, nprocs=1, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python gs.run_command("r.futures.gridvalidation", simulated="name", reference="name", allocation_disagreement="name", region="name", nprocs=1)
grass.tools.Tools.r_futures_gridvalidation(simulated, reference, original=None, allocation_disagreement=None, allocation_disagreement_basename=None, quantity_disagreement=None, quantity_disagreement_basename=None, kappa=None, kappasimulation=None, region, nprocs=1, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python tools = Tools() tools.r_futures_gridvalidation(simulated="name", reference="name", allocation_disagreement="name", region="name", nprocs=1)
Parameters
simulated=name [required]
    Simulated land use raster
reference=name [required]
    Reference land use raster
original=name
    Original land use raster
    Required for kappa simulation
    Output total allocation disagreement raster
    Basename for per class allocation disagreement raster
    Output total quantity disagreement raster
    Basename for per class quantity disagreement raster
kappa=name
    Output Cohen's kappa raster
    Output kappa simulation raster
region=name [required]
    Name of saved region
nprocs=integer [required]
    Number of parallel processes
    Default: 1
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
simulated : str, required
    Used as: input, raster, name
reference : str, required
original : str, optional
allocation_disagreement : str, optional
    Used as: output, raster, name
allocation_disagreement_basename : str, optional
    Used as: output, raster, basename
quantity_disagreement : str, optional
quantity_disagreement_basename : str, optional
kappa : str, optional
kappasimulation : str, optional
region : str, required
    Used as: input, region, name
nprocs : int, required
    Default: 1
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
simulated : str | np.ndarray, required
reference : str | np.ndarray, required
original : str | np.ndarray, optional
allocation_disagreement : str | type(np.ndarray) | type(np.array) | type(gs.array.array), optional
allocation_disagreement_basename : str | type(np.ndarray) | type(np.array) | type(gs.array.array), optional
quantity_disagreement : str | type(np.ndarray) | type(np.array) | type(gs.array.array), optional
quantity_disagreement_basename : str | type(np.ndarray) | type(np.array) | type(gs.array.array), optional
kappa : str | type(np.ndarray) | type(np.array) | type(gs.array.array), optional
kappasimulation : str | type(np.ndarray) | type(np.array) | type(gs.array.array), optional
    Default: 1
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
Module r.futures.gridvalidation allows to validate land change simulation results on a spatial grid. It computes:
  • Allocation disagreement (total and per class), see Pontius et al, 2011
  • Quantity disagreement (total and per class), see Pontius et al, 2011
  • Cohen's Kappa
  • Kappa simulation, see van Vliet et al, 2011
These metrics are computed for each cell of a region provided in region option resulting in spatially variable validation results. Cell size of the region should be larger than the cell size of the current region.
This module can be used for any number of classes. Input raster original represents the initial conditions and is needed only for Kappa simulation.
EXAMPLES
Validate FUTURES output by computing quantity and allocation disagreement on a 5km grid. First reclassify FUTURES output to 0 (undeveloped) and 1 (developed) by creating a text file "rules.txt" with the following content:
text -1 = 0 0 thru 100 = 1
Then save a region used as a grid:
sh g.region res=5000 -a save=grid
Reclass FUTURES output:
sh r.reclass input=simulated_2016 output=simulated_2016_reclass rules=rules.txt
Validate FUTURES output by computing kappa simulation on a 5km grid:
sh r.futures.gridvalidation simulated=simulated_2016_reclass reference=reference_2016 original=orig_2001 kappasimulation=kappasim
SEE ALSO
FUTURES, r.futures.pga, r.futures.potential, r.futures.devpressure, r.futures.demand, r.futures.calib, r.sample.category
REFERENCES
AUTHOR
Anna Petrasova, NCSU GeoForAll
SOURCE CODE
Available at: r.futures.gridvalidation source code (history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
