Skip to content
r.sample.category
Create sampling points from each category in a raster map
r.sample.category [-s] input=name output=name [sampled=name [,name,...]] npoints=integer [,integer,...] [random_seed=integer] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh r.sample.category input=name output=name npoints=0
grass.script.run_command("r.sample.category", input, output, sampled=None, npoints, random_seed=None, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python gs.run_command("r.sample.category", input="name", output="name", npoints=0)
grass.tools.Tools.r_sample_category(input, output, sampled=None, npoints, random_seed=None, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python tools = Tools() tools.r_sample_category(input="name", output="name", npoints=0)
Parameters
input=name [required]
    Name of input raster map with categories (classes)
output=name [required]
    Name of output vector map with points at random locations
    Names of input raster maps to be sampled
npoints=integer [,integer,...] [required]
    Number of sampling points per category in the input map
    You can provide multiple numbers, one for each category in input raster (sorted ascending)
random_seed=integer
    Seed for random number generator
-s
    If number of cells in category < npoints, skip category
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
input : str, required
    Used as: input, raster, name
output : str, required
    Used as: output, vector, name
sampled : str | list[str], optional
npoints : int | list[int] | str, required
random_seed : int, optional
flags : str, optional
    Allowed values: s
    s
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
input : str | np.ndarray, required
    Allowed values: s
    s
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
r.sample.category generates points at random locations. Each category (class) in a raster map will contain specified number of random points.
Different number of points can be specified for different categories. For example, if there are categories 1, 4, 7 in the input raster map, and npoints=100,200,300, 100 points will be generated in category 1, 200 points in category 4 and 300 points in category 7. If only one number is specified, it will be used for every category.
NOTES
Mask (r.mask) to create points in areas with each category, thus mask cannot be active when the module is used.
Categories are identified based on current computational region.
EXAMPLE
Generate random points
Generate three points at random location for each category (class) in the raster map:
sh g.region raster=landclass96 r.sample.category input=landclass96 output=landclass_points npoints=3
Show the result:
sh d.rast map=landclass96 d.vect map=landclass_points icon=basic/circle fill_color=aqua color=blue size=10
image-alt
Figure: Three random points in each category of landclass raster map
Create a table with values sampled from rasters
Create 2 random points per each category (class) in landclass96 raster and sample elevation and geology_30m rasters at these points:
sh r.sample.category input=landclass96 output=landclass_points sampled=elevation,geology_30m npoints=2
Look at the created data:
sh v.db.select landclass_points sep=comma
The result of v.db.select is CSV table which can be used, for example in a spreadsheet application:
csv cat,landclass96,elevation,geology_30m 1,1,102.7855,270 2,1,105.78,270 3,2,114.5954,217 4,2,137.4816,921 5,3,71.19167,270 6,3,93.33904,270 7,4,76.41077,262 8,4,97.54424,217 9,5,138.455,405 10,5,88.8075,270 11,6,126.5298,217 12,6,86.73177,217 13,7,134.5381,217 14,7,99.6844,270
SEE ALSO
v.sample, r.random, r.random.cells, v.random, v.what.rast, r.describe
AUTHORS
Vaclav Petras, NCSU OSGeoREL,
Anna Petrasova, NCSU OSGeoREL
SOURCE CODE
Available at: r.sample.category source code (history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
