r.futures.potsurface
Module for computing development potential surface from CSV file created by r.futures.potential and predictors
r.futures.potsurface input=name subregions=name output=name [separator=character] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
grass.script.run_command("r.futures.potsurface", input, subregions, output, separator="comma", overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("r.futures.potsurface", input="name", subregions="name", output="name")
grass.tools.Tools.r_futures_potsurface(input, subregions, output, separator="comma", overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.r_futures_potsurface(input="name", subregions="name", output="name")
Parameters
input=name [required]
CSV file with coefficients
subregions=name [required]
Raster map of subregions
output=name [required]
Output probability raster
separator=character
Separator used in input CSV file
Special characters: pipe, comma, space, tab, newline
Default: comma
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
input : str, required
Used as: input, file, name
subregions : str, required
Used as: input, raster, name
output : str, required
Used as: output, raster, name
separator : str, optional
Used as: input, separator, character
Default: comma
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
input : str | io.StringIO, required
subregions : str | np.ndarray, required
Default: comma
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
Module r.futures.potsurface is a support tool for computing development probability surface based on maps and coefficients selected by r.futures.potential. It computes the initial probability surface used in the patch growing algorithm in r.futures.pga. It is not necessary to use this module, however it is useful to inspect the potential surface to better understand the input data and how the predictors influence the probability. The values range from 0 (unlikely to be developed) to 1 (high probability of development).
The inputs are the output file from r.futures.potential and the name of the subregions raster map.
EXAMPLES
r.futures.potsurface input=potential.csv subregions=counties output=pot_surface
Figure: We can visualize the potential surface in 3D and drape raster representing developed (red) and undeveloped (green) cells over it.
SEE ALSO
FUTURES, r.futures.pga, r.futures.potential, r.futures.devpressure, r.futures.demand, r.futures.calib, r.sample.category
REFERENCES
- Meentemeyer, R. K., Tang, W., Dorning, M. A., Vogler, J. B., Cunniffe, N. J., & Shoemaker, D. A. (2013). FUTURES: Multilevel Simulations of Emerging Urban-Rural Landscape Structure Using a Stochastic Patch-Growing Algorithm. Annals of the Association of American Geographers, 103(4), 785-807. DOI: 10.1080/00045608.2012.707591
- Dorning, M. A., Koch, J., Shoemaker, D. A., & Meentemeyer, R. K. (2015). Simulating urbanization scenarios reveals tradeoffs between conservation planning strategies. Landscape and Urban Planning, 136, 28-39. DOI: 10.1016/j.landurbplan.2014.11.011
- Petrasova, A., Petras, V., Van Berkel, D., Harmon, B. A., Mitasova, H., & Meentemeyer, R. K. (2016). Open Source Approach to Urban Growth Simulation. Int. Arch. Photogramm. Remote Sens. Spatial Inf. Sci., XLI-B7, 953-959. DOI: 10.5194/isprsarchives-XLI-B7-953-2016
AUTHOR
Anna Petrasova, NCSU GeoForAll
SOURCE CODE
Available at: r.futures.potsurface source code
(history)
Latest change: Friday Feb 21 10:10:05 2025 in commit 7d78fe3
