Skip to content
r.green.biomassfor.co2
Calculates impact and multifunctionality values
r.green.biomassfor.co2 [-r] forest=name boundaries=name forest_column_yield=string forest_column_yield_surface=string forest_column_management=string forest_column_treatment=string forest_roads=name [forest_column_roughness=string] [rivers=name] [lakes=name] [energy_tops_hf=float] [energy_cormometric_vol_hf=float] [energy_tops_cop=float] energy_map=name dhp=name [output_basename_co2map=name] [output_basename_aco2map=name] [output_basename_nco2map=name] [dtm=name] [forest_column_roughness=string] [soilp2_map=name] [tree_diam=name] [tree_vol=name] [main_roads=name] [slp_min_cc=float] [slp_max_cc=float] [dist_max_cc=float] [slp_max_fw=float] [dist_max_fw=float] [slp_max_cop=float] [dist_max_cop=float] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh r.green.biomassfor.co2 forest=name boundaries=name forest_column_yield=string forest_column_yield_surface=string forest_column_management=string forest_column_treatment=string forest_roads=name energy_map=name dhp=name
grass.script.run_command("r.green.biomassfor.co2", forest, boundaries, forest_column_yield, forest_column_yield_surface, forest_column_management, forest_column_treatment, forest_roads, forest_column_roughness=None, rivers=None, lakes=None, energy_tops_hf=0.49, energy_cormometric_vol_hf=1.97, energy_tops_cop=0.55, energy_map, dhp, output_basename_co2map=None, output_basename_aco2map=None, output_basename_nco2map=None, dtm=None, forest_column_roughness=None, soilp2_map=None, tree_diam=None, tree_vol=None, main_roads=None, slp_min_cc=30., slp_max_cc=100., dist_max_cc=800., slp_max_fw=30., dist_max_fw=600., slp_max_cop=30., dist_max_cop=600., flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python gs.run_command("r.green.biomassfor.co2", forest="name", boundaries="name", forest_column_yield="string", forest_column_yield_surface="string", forest_column_management="string", forest_column_treatment="string", forest_roads="name", energy_map="name", dhp="name")
grass.tools.Tools.r_green_biomassfor_co2(forest, boundaries, forest_column_yield, forest_column_yield_surface, forest_column_management, forest_column_treatment, forest_roads, forest_column_roughness=None, rivers=None, lakes=None, energy_tops_hf=0.49, energy_cormometric_vol_hf=1.97, energy_tops_cop=0.55, energy_map, dhp, output_basename_co2map=None, output_basename_aco2map=None, output_basename_nco2map=None, dtm=None, forest_column_roughness=None, soilp2_map=None, tree_diam=None, tree_vol=None, main_roads=None, slp_min_cc=30., slp_max_cc=100., dist_max_cc=800., slp_max_fw=30., dist_max_fw=600., slp_max_cop=30., dist_max_cop=600., flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python tools = Tools() tools.r_green_biomassfor_co2(forest="name", boundaries="name", forest_column_yield="string", forest_column_yield_surface="string", forest_column_management="string", forest_column_treatment="string", forest_roads="name", energy_map="name", dhp="name")
Parameters
forest=name [required]
    Name of vector parcel map
boundaries=name [required]
    Name of vector boundaries map (boolean map)
forest_column_yield=string [required]
    Vector field of yield
forest_column_yield_surface=string [required]
    Vector field of stand surface (ha)
forest_column_management=string [required]
    Vector field of forest management (1: high forest, 2:coppice)
forest_column_treatment=string [required]
    Vector field of forest treatment (1: final felling, 2:thinning)
forest_roads=name [required]
    Vector map of forest roads
    Vector field of roughness
rivers=name
    Vector map of rivers
lakes=name
    Vector map of lakes
    Vector map of lakes
    Energy for tops and branches in high forest in MWh/m3
    Default: 0.49
    Energy for tops and branches for high forest in MWh/m3
    Default: 1.97
    Energy for tops and branches for Coppices in MWh/m3
    Default: 0.55
energy_map=name [required]
    Bioenergy map in MWh/m3
dhp=name [required]
    Name of vector district heating points
    Name for output CO2 emissions map
    Name for output avoided CO2 emissions map
    Name for output net CO2 emissions map
dtm=name
    Name of Digital terrain model map
soilp2_map=name
    Soil production map
tree_diam=name
    Average tree diameter map
tree_vol=name
    Average tree volume map
main_roads=name
    Vector map of main roads
slp_min_cc=float
    Percent slope lower limit with Cable Crane
    Default: 30.
slp_max_cc=float
    Percent slope higher limit with Cable Crane
    Default: 100.
dist_max_cc=float
    Maximum distance with Cable Crane
    Default: 800.
slp_max_fw=float
    Percent slope higher limit with Forwarder
    Default: 30.
dist_max_fw=float
    Maximum distance with Forwarder
    Default: 600.
slp_max_cop=float
    Percent slope higher limit with other techniques for Coppices
    Default: 30.
dist_max_cop=float
    Maximum distance with other techniques for Coppices
    Default: 600.
-r
    Remove all operational maps
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
forest : str, required
    Used as: input, vector, name
boundaries : str, required
forest_column_yield : str, required
forest_column_yield_surface : str, required
forest_column_management : str, required
forest_column_treatment : str, required
forest_roads : str, required
forest_column_roughness : str, optional
rivers : str, optional
lakes : str, optional
    Vector map of lakes
    Vector map of lakes
energy_tops_hf : float, optional
    Default: 0.49
energy_cormometric_vol_hf : float, optional
    Default: 1.97
energy_tops_cop : float, optional
    Default: 0.55
energy_map : str, required
    Used as: input, raster, name
dhp : str, required
output_basename_co2map : str, optional
    Used as: output, , name
output_basename_aco2map : str, optional
output_basename_nco2map : str, optional
dtm : str, optional
soilp2_map : str, optional
    Soil production map
tree_diam : str, optional
tree_vol : str, optional
main_roads : str, optional
slp_min_cc : float, optional
    Default: 30.
slp_max_cc : float, optional
    Default: 100.
dist_max_cc : float, optional
    Default: 800.
slp_max_fw : float, optional
    Default: 30.
dist_max_fw : float, optional
    Default: 600.
slp_max_cop : float, optional
    Default: 30.
dist_max_cop : float, optional
    Default: 600.
flags : str, optional
    Allowed values: r
    r
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
    Vector map of lakes
    Vector map of lakes
    Default: 0.49
    Default: 1.97
    Default: 0.55
energy_map : str | np.ndarray, required
dhp : str, required
dtm : str | np.ndarray, optional
soilp2_map : str | np.ndarray, optional
    Soil production map
tree_diam : str | np.ndarray, optional
tree_vol : str | np.ndarray, optional
    Default: 30.
    Default: 100.
    Default: 800.
    Default: 30.
    Default: 600.
    Default: 30.
    Default: 600.
    Allowed values: r
    r
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
Compute the CO2 emissions of using biomass forestry residuals for energy production.
NOTES
EXAMPLE
REFERENCE
SEE ALSO
r.green, r.green.biomassfor
AUTHORS
Francesco Geri, Pietro Zambelli, Sandro Sacchelli, Marco Ciolli
SOURCE CODE
Available at: r.green.biomassfor.co2 source code (history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
