Skip to content
r.green.gshp.technical
Calculate the Ground Source Heat Pump technical potential using the ASHRAE method.
r.green.gshp.technical [-d] ground_conductivity=name [ground_diffusivity_rast=name] [ground_diffusivity_value=double] [ground_temp_rast=name] [ground_temp_value=double] [g_loads_6h_rast=name] [g_loads_6h_value=double] [g_loads_1m_rast=name] [g_loads_1m_value=double] [g_loads_1y_rast=name] [g_loads_1y_value=double] [fluid_capacity=double] [fluid_massflow=double] [fluid_inlettemp=double] [bh_radius=double] [bh_convection=double] [bh_resistence=double] [pipe_inner_radius=double] [pipe_outer_radius=double] [pipe_distance=double] [k_pipe=double] [k_grout=double] [field_distance=double] [field_number=integer] [field_ratio=double] [bhe_length=name] [bhe_field_length=name] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh r.green.gshp.technical ground_conductivity=name
grass.script.run_command("r.green.gshp.technical", ground_conductivity, ground_diffusivity_rast=None, ground_diffusivity_value=0.086, ground_temp_rast=None, ground_temp_value=10., g_loads_6h_rast=None, g_loads_6h_value=60., g_loads_1m_rast=None, g_loads_1m_value=15., g_loads_1y_rast=None, g_loads_1y_value=5., fluid_capacity=4200., fluid_massflow=0.050, fluid_inlettemp=2., bh_radius=0.06, bh_convection=1.52, bh_resistence=nan, pipe_inner_radius=0.01365, pipe_outer_radius=0.0167, pipe_distance=0.0511, k_pipe=0.42, k_grout=1.52, field_distance=6.1, field_number=2, field_ratio=1.2, bhe_length=None, bhe_field_length=None, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python gs.run_command("r.green.gshp.technical", ground_conductivity="name")
grass.tools.Tools.r_green_gshp_technical(ground_conductivity, ground_diffusivity_rast=None, ground_diffusivity_value=0.086, ground_temp_rast=None, ground_temp_value=10., g_loads_6h_rast=None, g_loads_6h_value=60., g_loads_1m_rast=None, g_loads_1m_value=15., g_loads_1y_rast=None, g_loads_1y_value=5., fluid_capacity=4200., fluid_massflow=0.050, fluid_inlettemp=2., bh_radius=0.06, bh_convection=1.52, bh_resistence=nan, pipe_inner_radius=0.01365, pipe_outer_radius=0.0167, pipe_distance=0.0511, k_pipe=0.42, k_grout=1.52, field_distance=6.1, field_number=2, field_ratio=1.2, bhe_length=None, bhe_field_length=None, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python tools = Tools() tools.r_green_gshp_technical(ground_conductivity="name")
Parameters
ground_conductivity=name [required]
    Raster with depth-averaged ground thermal conductivity lambda [W m-1 K-1]
    Raster with depth-averaged ground diffusivity [m2 day-1]
    Value with depth-averaged ground diffusivity [m2 day-1]
    Default: 0.086
    Raster with the initial ground temperature T0 [degrees C]
    Value with the initial ground temperature T0 [degrees C]
    Default: 10.
    Peak of the maximum 6 hourly ground loads [W]
    Default: 60.
    Month with the maximum ground loads [W]
    Default: 15.
    Yearly average ground loads [W]
    Default: 5.
    Fluid capacity Cp [J kg-1 K-1]
    Default: 4200.
    Fluid massflow [kg s-1 kW-1]
    Default: 0.050
    Inlet temperature [degrees C]
    Default: 2.
bh_radius=double
    Borehole radius [m]
    Default: 0.06
    Internal convection coefficient [W m-2 K-1]
    Default: 1.52
    Borehole thermal resistance [m K W-1]
    Default: nan
    Borehole pipe inner radius [m]
    Default: 0.01365
    Borehole pipe outer radius [m]
    Default: 0.0167
    Center-to-center distance between pipes [m]
    Default: 0.0511
k_pipe=double
    Pipe thermal conductivity [W m-1 K-1]
    Default: 0.42
k_grout=double
    Grout thermal conductivity [W m-1 K-1]
    Default: 1.52
    Distance between boreholes heat exchanger
    Default: 6.1
    Number of borehole heat exchanger
    Default: 2
field_ratio=double
    Borefield aspect ratio
    Default: 1.2
bhe_length=name
    Name of output raster map with the geothermal length of the BHE [m]
    Name of output raster map with the geothermal length of the BHE field [m]
-d
    Debug with intermediate maps
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
ground_conductivity : str, required
    Used as: input, raster, name
ground_diffusivity_rast : str, optional
ground_diffusivity_value : float, optional
    Used as: double
    Default: 0.086
ground_temp_rast : str, optional
ground_temp_value : float, optional
    Used as: double
    Default: 10.
g_loads_6h_rast : str, optional
g_loads_6h_value : float, optional
    Used as: double
    Default: 60.
g_loads_1m_rast : str, optional
g_loads_1m_value : float, optional
    Used as: double
    Default: 15.
g_loads_1y_rast : str, optional
g_loads_1y_value : float, optional
    Used as: double
    Default: 5.
fluid_capacity : float, optional
    Used as: double
    Default: 4200.
fluid_massflow : float, optional
    Used as: double
    Default: 0.050
fluid_inlettemp : float, optional
    Used as: double
    Default: 2.
bh_radius : float, optional
    Borehole radius [m]
    Used as: double
    Default: 0.06
bh_convection : float, optional
    Used as: double
    Default: 1.52
bh_resistence : float, optional
    Used as: double
    Default: nan
pipe_inner_radius : float, optional
    Used as: double
    Default: 0.01365
pipe_outer_radius : float, optional
    Used as: double
    Default: 0.0167
pipe_distance : float, optional
    Used as: double
    Default: 0.0511
k_pipe : float, optional
    Used as: double
    Default: 0.42
k_grout : float, optional
    Used as: double
    Default: 1.52
field_distance : float, optional
    Used as: double
    Default: 6.1
field_number : int, optional
    Used as: integer
    Default: 2
field_ratio : float, optional
    Used as: double
    Default: 1.2
bhe_length : str, optional
    Used as: output, raster, name
bhe_field_length : str, optional
flags : str, optional
    Allowed values: d
    d
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
ground_conductivity : str | np.ndarray, required
ground_diffusivity_rast : str | np.ndarray, optional
    Used as: double
    Default: 0.086
ground_temp_rast : str | np.ndarray, optional
    Used as: double
    Default: 10.
g_loads_6h_rast : str | np.ndarray, optional
    Used as: double
    Default: 60.
g_loads_1m_rast : str | np.ndarray, optional
    Used as: double
    Default: 15.
g_loads_1y_rast : str | np.ndarray, optional
    Used as: double
    Default: 5.
    Used as: double
    Default: 4200.
    Used as: double
    Default: 0.050
    Used as: double
    Default: 2.
    Borehole radius [m]
    Used as: double
    Default: 0.06
    Used as: double
    Default: 1.52
    Used as: double
    Default: nan
    Used as: double
    Default: 0.01365
    Used as: double
    Default: 0.0167
    Used as: double
    Default: 0.0511
    Used as: double
    Default: 0.42
    Used as: double
    Default: 1.52
    Used as: double
    Default: 6.1
    Used as: integer
    Default: 2
    Used as: double
    Default: 1.2
bhe_length : str | type(np.ndarray) | type(np.array) | type(gs.array.array), optional
bhe_field_length : str | type(np.ndarray) | type(np.array) | type(gs.array.array), optional
    Allowed values: d
    d
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
r.green.gshp.technical calculates the lenght of the borehole for Groud Source Heat Pump plants.
NOTES
The required inputs are the ground source conductivity and the ground loads.
EXAMPLES
sh python r.green.gshp.technical.py --overwrite ground_conductivity=g_conductivity ground_diffusivity_rast=g_diffusivity ground_temp_rast=g_temperature g_loads_6h_rast=g_loads_6h g_loads_1m_rast=g_loads_1m g_loads_1y_rast=g_loads_1y fluid_capacity=4000. fluid_massflow=0.074 fluid_inlettemp=4.44 bh_radius=0.054 pipe_inner_radius=0.01365 pipe_outer_radius=0.0167 bh_convection=1000. pipe_distance=0.0471 k_pipe=0.45 k_grout=1.73 field_distance=6.1 field_number=120 field_ratio=1.2 bhe_length=len_bhe bhe_field_length=len_bhe_field -d
SEE ALSO
AUTHOR
Pietro Zambelli (Eurac Research, Bolzano, Italy)
SOURCE CODE
Available at: r.green.gshp.technical source code (history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
