r.green.gshp.theoretical
Calculate the Ground Source Heat Pump potential
r.green.gshp.theoretical [-d] ground_conductivity=name [heating_season_raster=name] [heating_season_value=double] [power_value=double] [ground_capacity_raster=name] [ground_capacity_value=double] [ground_temp_raster=name] [ground_temp_value=double] [borehole_radius=double] [borehole_resistence=double] [borehole_length=double] [pipe_radius=double] [number_pipes=integer] [grout_conductivity=double] [fluid_limit_temperature=double] [lifetime=integer] power=name energy=name [length=name] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh
r.green.gshp.theoretical ground_conductivity=name power=name energy=name
grass.script.run_command("r.green.gshp.theoretical", ground_conductivity, heating_season_raster=None, heating_season_value=180., power_value=nan, ground_capacity_raster=None, ground_capacity_value=2.5, ground_temp_raster=None, ground_temp_value=10., borehole_radius=0.075, borehole_resistence=nan, borehole_length=100, pipe_radius=0.016, number_pipes=4, grout_conductivity=2, fluid_limit_temperature=-2, lifetime=50, power, energy, length=None, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
gs.run_command("r.green.gshp.theoretical", ground_conductivity="name", power="name", energy="name")
grass.tools.Tools.r_green_gshp_theoretical(ground_conductivity, heating_season_raster=None, heating_season_value=180., power_value=nan, ground_capacity_raster=None, ground_capacity_value=2.5, ground_temp_raster=None, ground_temp_value=10., borehole_radius=0.075, borehole_resistence=nan, borehole_length=100, pipe_radius=0.016, number_pipes=4, grout_conductivity=2, fluid_limit_temperature=-2, lifetime=50, power, energy, length=None, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
tools = Tools()
tools.r_green_gshp_theoretical(ground_conductivity="name", power="name", energy="name")
Parameters
ground_conductivity=name [required]
Raster with depth-averaged ground thermal conductivity lambda [W m-1 K-1]
Raster with the Heating Season [0-365] days
Allowed values: 0-365
Default: 180.
power_value=double
Power value in kW
Default: nan
Raster with depth-averaged ground thermal capacity rho_c [MJ m-3 K-1]
Value with depth-averaged ground thermal capacity rho_c [MJ m-3 K-1]
Default: 2.5
Raster with the initial ground temperature T0 [degrees C]
Value with the initial ground temperature T0 [degrees C]
Default: 10.
Borehole radius [m]
Default: 0.075
Borehole thermal resistance [m K W-1]
Default: nan
Borehole length [m]
Default: 100
pipe_radius=double
Pipe radius [m]
Default: 0.016
Number of pipes in the borehole
Default: 4
Thermal conductivity of the borehole filling (geothermal grout) [W m-1 K-1]
Default: 2
Minimum or maximum fluid temperature [degrees C]
Default: -2
lifetime=integer
Simulated lifetime of the plant [years]
Default: 50
power=name [required]
Name of output raster map with the geothermal power potential [W]
energy=name [required]
Name of output raster map with the geothermal energy potential [MWh]
length=name
Name of output raster map with the geothermal length of the BHE [m]
-d
Debug with intermediate maps
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
ground_conductivity : str, required
Used as: input, raster, name
heating_season_raster : str, optional
heating_season_value : float, optional
Used as: double
Default: 180.
power_value : float, optional
Power value in kW
Used as: double
Default: nan
ground_capacity_raster : str, optional
ground_capacity_value : float, optional
Used as: double
Default: 2.5
ground_temp_raster : str, optional
ground_temp_value : float, optional
Used as: double
Default: 10.
borehole_radius : float, optional
Borehole radius [m]
Used as: double
Default: 0.075
borehole_resistence : float, optional
Used as: double
Default: nan
borehole_length : float, optional
Borehole length [m]
Used as: double
Default: 100
pipe_radius : float, optional
Pipe radius [m]
Used as: double
Default: 0.016
number_pipes : int, optional
Used as: integer
Default: 4
grout_conductivity : float, optional
Used as: double
Default: 2
fluid_limit_temperature : float, optional
Used as: double
Default: -2
lifetime : int, optional
Used as: integer
Default: 50
power : str, required
Used as: output, raster, name
energy : str, required
length : str, optional
flags : str, optional
Allowed values: d
d
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
ground_conductivity : str | np.ndarray, required
heating_season_raster : str | np.ndarray, optional
Used as: double
Default: 180.
Power value in kW
Used as: double
Default: nan
ground_capacity_raster : str | np.ndarray, optional
Used as: double
Default: 2.5
ground_temp_raster : str | np.ndarray, optional
Used as: double
Default: 10.
Borehole radius [m]
Used as: double
Default: 0.075
Used as: double
Default: nan
Borehole length [m]
Used as: double
Default: 100
Pipe radius [m]
Used as: double
Default: 0.016
Used as: integer
Default: 4
Used as: double
Default: 2
Used as: double
Default: -2
Used as: integer
Default: 50
power : str | type(np.ndarray) | type(np.array) | type(gs.array.array), required
energy : str | type(np.ndarray) | type(np.array) | type(gs.array.array), required
length : str | type(np.ndarray) | type(np.array) | type(gs.array.array), optional
Allowed values: d
d
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
r.green.gshp.theoretical assess the shallow geothermal potential defined as the thermal power exchanged by a Borehole Heat Exchanger of a certain depth. This potential depends on the thermal properties of the ground and the plant features. This module returns two output raster maps with the the energy potential (MWh/year) and the power potential (W). In this module the output is the theoretical maximum energy that can be converted in the ideal case without considering the financial and spatial constraints.
NOTES
The required inputs are the the thermal conductivity. If not specific values are indicated, reference values have been assumed for the ground features and the plant.
EXPLANATION
r.green.gshp.theoretical calculates the potential of shallow geothermal energy by means of and empirical relationship proposed by Casasso et al. (2016) as:
Pgshp=8*(T0 - Tlim) λ L t'c/(-0.619 t'c log(u's)-0.455 t'c-1.619+4 π Rb)
where
T0 is the undisturbed ground temperature (°C),
Tlim the threshold temperature of the heat carrier fluid
setting to 2°C,
λ is the the thermal conductivity of the ground (W/(mK)),
L the borehole length (m),
t'c is is the operating time ratio ,
u's is a parameter depending on the simulaion time and
the borehole radius ,
Rb is the thermal resistance (K/W)
EXAMPLES
This example is based on the case-study of the EUSALP region, located in Europe and covering part of Italian, Slovenian, Austrian, German, Swiss and France territories. The data can be downloades at the following repositories EUSALP dataset.
sh
r.green.gshp.theoretical \
ground_conductivity=conductivity \
heating_season_raster=season_heating \
ground_temp_raster=ground_temperature \
ground_capacity_value=2.3 \
power=gpot_power \
energy=gpot_energy \
REFERENCES
Alessandro Casasso, Rajandrea Sethi, 2016,
"G.POT: A quantitative method for the assessment and mapping of the
shallow geothermal potential"
Energy 106, p 765 --
https://doi.org/10.1016/j.energy.2016.03.091
SEE ALSO
r.green.hydro.technical, r.green.hydro.technical
AUTHORS
Pietro Zambelli (Eurac Research, Bolzano, Italy), Tested by and manual written by Giulia Garegnani
SOURCE CODE
Available at: r.green.gshp.theoretical source code
(history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
