r.green.hydro.closest
Move points to the closest vector map
r.green.hydro.closest points=name lines=name output=name max_dist=float [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
r.green.hydro.closest points=name lines=name output=name max_dist=10
grass.script.run_command("r.green.hydro.closest", points, lines, output, max_dist=10, overwrite=False, verbose=False, quiet=False, superquiet=False)
Example:
gs.run_command("r.green.hydro.closest", points="name", lines="name", output="name", max_dist=10)
Parameters
points=name [required]
Name of input vector map
Or data source for direct OGR access
lines=name [required]
output=name [required]
Name for output vector map
max_dist=float [required]
Maximum distance from points to river
Default: 10
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
points : str, required
Used as: input, vector, name
lines : str, required
output : str, required
Used as: output, vector, name
max_dist : float, required
Default: 10
overwrite: bool, optional
Default: False
verbose: bool, optional
Default: False
quiet: bool, optional
Quiet module output
Default: False
superquiet: bool, optional
Default: False
DESCRIPTION
SEE ALSO
AUTHOR
Pietro Zambelli
SOURCE CODE
Available at: r.green.hydro.closest source code
(history)
Latest change: Thursday Feb 20 13:02:26 2025 in commit 53de819
