Skip to content
r.northerness.easterness
Calculation of northerness, easterness and the interaction between northerness and slope
r.northerness.easterness elevation=name [--verbose] [--quiet] [--qq] [--ui]
Example:
sh r.northerness.easterness elevation=name
grass.script.run_command("r.northerness.easterness", elevation, verbose=None, quiet=None, superquiet=None)
Example:
python gs.run_command("r.northerness.easterness", elevation="name")
grass.tools.Tools.r_northerness_easterness(elevation, verbose=None, quiet=None, superquiet=None)
Example:
python tools = Tools() tools.r_northerness_easterness(elevation="name")
Parameters
elevation=name [required]
    Name of elevation raster map
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
elevation : str, required
    Used as: input, raster, name
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
elevation : str | np.ndarray, required
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
r.northerness.easterness calculates northerness, easterness and the interaction between northerness and slope (northerness*slope). The user must specify the input elevation raster map.
NOTES
As aspect is a circular land-surface parameter, in ecology a sine or cosine transformation is often used to obtain a continuous gradient, stressing the north-south or east-west gradient (northness or eastness).
The GRASS GIS default aspect angles (cartesian) are converted to compass angles.
Calculated raster maps are:
  • northerness: cos(aspect)
  • easterness: sin(aspect)
  • interaction between northerness and slope: northerness*slope
The color of these raster maps are set to grey.
EXAMPLE
```sh # align region to DEM and habitat vector g.region -a raster=DEM align=DEM
# run r.northerness.easterness r.northerness.easterness elevation=DEM
REFERENCES
Olaya, V. 2009. Basic Land-Surface Parameters. In: Hengl, T. & Reuter, H.I. (eds.) 2009. Geomorphometry. Concepts, Software, Applications. Developments in Soil Science, Volume 33. Elsevier.
SEE ALSO
r.mapcalc, r.slope.aspect
AUTHOR
Helmut Kudrnovsky
SOURCE CODE
Available at: r.northerness.easterness source code (history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
