Skip to content
r.object.spatialautocor
Spatial autocorrelation of raster objects
r.object.spatialautocor [-d] object_map=name variable_map=name method=string [--verbose] [--quiet] [--qq] [--ui]
Example:
sh r.object.spatialautocor object_map=name variable_map=name method=moran
grass.script.run_command("r.object.spatialautocor", object_map, variable_map, method, flags=None, verbose=None, quiet=None, superquiet=None)
Example:
python gs.run_command("r.object.spatialautocor", object_map="name", variable_map="name", method="moran")
grass.tools.Tools.r_object_spatialautocor(object_map, variable_map, method, flags=None, verbose=None, quiet=None, superquiet=None)
Example:
python tools = Tools() tools.r_object_spatialautocor(object_map="name", variable_map="name", method="moran")
Parameters
object_map=name [required]
    Raster input map with objects
variable_map=name [required]
    Raster input map with variable
method=string [required]
    Method for spatial autocorrelation
    Allowed values: moran, geary
-d
    Also take into account diagonal neighbors
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
object_map : str, required
    Used as: input, raster, name
variable_map : str, required
method : str, required
flags : str, optional
    Allowed values: d
    d
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
object_map : str | np.ndarray, required
variable_map : str | np.ndarray, required
    Allowed values: d
    d
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
r.object.spatialautocor calculates global spatial autocorrelation of the raster objects in the object_map based on the values in the variable_map. The user can choose between Moran's I or Geary's G indicator using the method parameter.
At this stage, neighborhood is simply defined by an adjancy matrix. The user can choose whether to also accept diagonal neighborhood by setting the -d flag.
NOTES
The module depends on the addon r.neighborhoodmatrix which needs to be installed.
EXAMPLE
Calculate the spatial autocorrelation of altitude in the elevation map using individual patches in the landclass96 (North Carolina sample dataset) as objects:
sh g.region raster=elevation r.clump landclass96 output=objects r.object.spatialautocor ob=objects var=elevation method=moran r.object.spatialautocor ob=objects var=elevation method=geary
REFERENCES
Moran, P.A.P., 1950. Notes on Continuous Stochastic Phenomena. Biometrika 37, 17-23. https://dx.doi.org/10.2307%2F2332142
Geary, R.C., 1954. The Contiguity Ratio and Statistical Mapping. The Incorporated Statistician 5, 115. https://dx.doi.org/10.2307%2F2986645
SEE ALSO
AUTHOR
Moritz Lennert
SOURCE CODE
Available at: r.object.spatialautocor source code (history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
