r.neighborhoodmatrix
Calculates geometry parameters for raster objects.
r.neighborhoodmatrix [-dlc] input=name [output=name] [separator=character] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
r.neighborhoodmatrix input=name
grass.script.run_command("r.neighborhoodmatrix", input, output=None, separator="pipe", flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("r.neighborhoodmatrix", input="name")
grass.tools.Tools.r_neighborhoodmatrix(input, output=None, separator="pipe", flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.r_neighborhoodmatrix(input="name")
Parameters
input=name [required]
Raster for which to calculate the neighboorhood matrix
output=name
Name for output file
separator=character
Field separator
Special characters: pipe, comma, space, tab, newline
Default: pipe
-d
Also take into account diagonal neighbors
-l
Also output length of common border (in pixels)
-c
Include column names in output (meaning will be inversed soon)
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
input : str, required
Used as: input, raster, name
output : str, optional
Used as: output, file, name
separator : str, optional
Field separator
Used as: input, separator, character
Default: pipe
flags : str, optional
Allowed values: d, l, c
d
l
c
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
input : str | np.ndarray, required
Field separator
Default: pipe
d
l
c
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
r.neighborhoodmatrix identifies all adjacency relations between objects (aka segments or clumps identified by identical integer cell values of adjacent pixels) in a raster map and exports these as a 2xn matrix where n is the number of neighborhood relations with each relation listed in both directions (i.e. if a is neighbor of b, the list will contain a,b and b,a). If a path to an output file is specified, the matrix will be written to that file, otherwise it will be sent to standard output.
Neighborhood relations are determined pixel by pixel, and by default only pixels that share a common pixel boundary are considered neighbors. When the -d flag is set pixels sharing a common corner (i.e. diagonal neighbors) are also taken into account.
When the -l flag is set, the module additionally indicates the length of the common border between two neighbors in number of pixels. As this length is not clearly defined for diagonal neighbors, the -l flag cannot be used in combination with the -d flag.
The -c flag currently adds column headers. Please note that this flag's meaning will be inversed when GRASS 8 comes out in order to harmonize its behaviour with that in other modules.
NOTES
As neighborhood length is measured in pixels, this length is not in proportion to length in map units if the location is a lat-long location, or if the resolution is not the same in East-West and in North-South direction (rectangular pixels).
The module respects the region settings, so if the raster map is outside the current computational region, the resulting list of neighbors will be empty.
TODO
- Add flag to only output half matrix with each relation only shown once.
- Measure neighbordhood length in map units, not only pixels
EXAMPLE
Start by making sure the input map is of type CELL:
r.mapcalc "bc_int = int(boundary_county_500m)"
Send the neighborhood matrix of the counties in the boundary_county map of the North Carolina dataset to standard output:
r.neighborhoodmatrix input=bc_int sep=comma
Idem, but also calculating neighborhood length, sending the output to a file:
r.neighborhoodmatrix -l input=bc_int sep=comma output=county_neighbors.csv
SEE ALSO
AUTHORS
Original Python-Version: Moritz Lennert
C-Version: Markus Metz
SOURCE CODE
Available at: r.neighborhoodmatrix source code
(history)
Latest change: Tuesday Mar 03 04:02:16 2026 in commit 67ae2f5
