Skip to content
t.rast.aggregate.seasons
Calculates seasonal data according to astronomical seasons.
t.rast.aggregate.seasons [-nm] input=name [output=name] [years=string [,string,...]] basename=string method=string [nprocs=integer] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
t.rast.aggregate.seasons input=name basename=string method=average
grass.tools.Tools.t_rast_aggregate_seasons(input, output=None, years=None, basename, method="average", nprocs=1, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.t_rast_aggregate_seasons(input="name", basename="string", method="average")
grass.script.run_command("t.rast.aggregate.seasons", input, output=None, years=None, basename, method="average", nprocs=1, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("t.rast.aggregate.seasons", input="name", basename="string", method="average")
Parameters
input=name [required]
    Name of the input space time raster dataset
output=name
    The name of a singular space time raster dataset
    Using this option all the yearly space time raster datasets will be merged in a singular space time raster dataset
    List of years, separator may be comma (list) or minus (range)
basename=string [required]
    Basename of the new generated output maps and space time raster datasets if output option is not used
    A numerical suffix separated by an underscore will be attached to create a unique identifier
method=string [required]
    Aggregate operation to be performed on the raster maps
    Allowed values: average, count, median, mode, minimum, min_raster, maximum, max_raster, stddev, range, sum, variance, diversity, slope, offset, detcoeff, quart1, quart3, perc90, quantile, skewness, kurtosis
    Default: average
nprocs=integer
    Number of processes to run in parallel
    Default: 1
-n
    Register Null maps
-m
    Use meteorological seasons
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
input : str, required
    Used as: input, strds, name
output : str, optional
    Used as: output, strds, name
years : str | list[str], optional
basename : str, required
    Used as:
method : str, required
    Default: average
nprocs : int, optional
    Default: 1
flags : str, optional
    Allowed values: n, m
    n
        Register Null maps
    m
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
Returns:
Raises:
    Used as:
    Default: average
    Default: 1
    n
        Register Null maps
    m
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
DESCRIPTION
t.rast.aggregate.seasons aggregates an input space time raster dataset astronomical or meteorological seasons using a statistical method selected by the user. It uses t.rast.aggregate.ds to detect and copy the seasons granularity.
Astronomical seasons are defined as:
  • Spring 20 March - 21 June
  • Summer 21 June - 20 September
  • Autumn 20 September - 21 December
  • Winter 21 December - 20 March (following year)
Meteorological seasons are defined as:
  • Spring 1 March - 31 May
  • Summer 1 June - 30 August
  • Autumn 1 September - 30 November
  • Winter 1 December - 28/29 Februay (following year)
Using the output option, the tool will create a single unified space time raster dataset with the name provided, otherwise it will create a space time raster dataset for each year in the input space time raster dataset.
EXAMPLES
Aggregate the input space-time raster dataset into astronomical seasons and create a unified output space-time raster dataset
t.rast.aggregate.seasons input=mystrds basename=mystrds_seasons output=outstrds
Aggregate the input space-time raster dataset into meteorological seasons and create an output space-time raster dataset for a selected year
t.rast.aggregate.seasons -m input=mystrds basename=mystrds_seasons_meteo \
    output=outstrds_meteo year=2014
NOTES
If one of the seasons is not fully covered by the input space time raster dataset, that season will not be created by the tool. For example if you have a daily space time raster dataset for just one year it will create only raster maps for 3 seasons (Spring, Summer, Autumn), the Winter will be avoided since your input dataset has data only until the end of the year but it misses the data from January to March.
SEE ALSO
t.rast.aggregate.ds, r.null
AUTHOR
Luca Delucchi, Fondazione Edmund Mach
SOURCE CODE
Available at: t.rast.aggregate.seasons source code (history)
Latest change: Saturday Jul 18 20:15:59 2026 in commit a413cbc
