Skip to content
t.rast.climatologies
Calculates climatologies from a space time raster dataset of absolute temporal type
t.rast.climatologies [-s] input=name [output=name] basename=string method=string [,string,...] [quantile=float [,float,...]] granularity=string [where=sql_query] [nprocs=integer] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
t.rast.climatologies input=name basename=string method=average granularity=day
grass.tools.Tools.t_rast_climatologies(input, output=None, basename, method="average", quantile=None, granularity="day", where=None, nprocs=1, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.t_rast_climatologies(input="name", basename="string", method="average", granularity="day")
grass.script.run_command("t.rast.climatologies", input, output=None, basename, method="average", quantile=None, granularity="day", where=None, nprocs=1, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("t.rast.climatologies", input="name", basename="string", method="average", granularity="day")
Parameters
input=name [required]
    Name of the input space time raster dataset
output=name
    Name of the output space time raster dataset
basename=string [required]
    Basename of the newly generated output maps
    Either a numerical suffix or the start time (s-flag) separated by an underscore will be attached to create a unique identifier
method=string [,string,...] [required]
    Aggregate operation to be performed on the raster maps
    Allowed values: average, count, median, mode, minimum, min_raster, maximum, max_raster, stddev, range, sum, variance, diversity, slope, offset, detcoeff, quart1, quart3, perc90, quantile, skewness, kurtosis
    Default: average
    Quantile to calculate for method=quantile
    Allowed values: 0.0-1.0
granularity=string [required]
    Aggregate by day or month
    Allowed values: day, 15 days, month
    Default: day
where=sql_query
    WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework
    Example: start_time > '2001-01-01 12:30:00'
nprocs=integer
    Number of processes to run in parallel
    Default: 1
-s
    Do not create a space time raster dataset as output
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
input : str, required
    Used as: input, strds, name
output : str, optional
    Used as: output, strds, name
basename : str, required
    Used as:
method : str | list[str], required
    Default: average
quantile : float | list[float] | str, optional
granularity : str, required
    Default: day
where : str, optional
    Used as: sql_query
nprocs : int, optional
    Default: 1
flags : str, optional
    Allowed values: s
    s
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
Returns:
Raises:
    Used as:
    Default: average
    Default: day
    Used as: sql_query
    Default: 1
    Allowed values: s
    s
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
DESCRIPTION
t.rast.climatologies is a module to calculate climatologies, i.e., long term stats, for single days or months in a time series. If the s flag is used, the module outputs a new space time raster dataset of relative temporal type with the aggregated maps.
EXAMPLE
Daily climatologies
Starting from a space time raster dataset of daily granularity (or granularity lower than one day), the module will create a new space time raster dataset of relative temporal type containing the long term average for each day along years.
t.rast.climatologies input=myinput output=dailyoutput
15 days climatologies
Starting from a space time raster dataset of daily granularity (or granularity lower than one day), the module will create a new space time raster dataset of relative temporal type containing the long term average every 15 days starting from 1st January.
t.rast.climatologies input=myinput output=dailyoutput granularity='15 days'
Monthly climatologies
Starting from a space time raster dataset of monthly granularity (or lower than one month), the module will create two new space time raster datasets containing the long term minimum and maximum for each month along years.
t.rast.climatologies input=myinput granularity=month method=min,max \
   output=monthlyoutputmin,monthlyoutputmax
SEE ALSO
r.series, t.rast.series
AUTHOR
Luca Delucchi, Fondazione Edmund Mach
SOURCE CODE
Available at: t.rast.climatologies source code (history)
Latest change: Monday Jul 20 07:38:42 2026 in commit 2475d99
