v.net.salesman
Creates a cycle connecting given nodes (Traveling salesman problem).
Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal
v.net.salesman [-tg] input=name output=name center_cats=range arc_layer=string arc_type=string [,string,...] node_layer=string [arc_column=string] [arc_backward_column=string] [turn_layer=string] [turn_cat_layer=string] [sequence=name] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
v.net.salesman input=name output=name center_cats=range arc_layer=1 arc_type=line,boundary node_layer=2
grass.script.run_command("v.net.salesman", input, output, center_cats, arc_layer="1", arc_type="line,boundary", node_layer="2", arc_column=None, arc_backward_column=None, turn_layer="3", turn_cat_layer="4", sequence=None, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("v.net.salesman", input="name", output="name", center_cats="range", arc_layer="1", arc_type="line,boundary", node_layer="2")
grass.tools.Tools.v_net_salesman(input, output, center_cats, arc_layer="1", arc_type="line,boundary", node_layer="2", arc_column=None, arc_backward_column=None, turn_layer="3", turn_cat_layer="4", sequence=None, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.v_net_salesman(input="name", output="name", center_cats="range", arc_layer="1", arc_type="line,boundary", node_layer="2")
Parameters
input=name [required]
    Name of input vector map
    Or data source for direct OGR access
output=name [required]
    Name for output vector map
center_cats=range [required]
    Category values
    Categories of points ('cities') on nodes (layer is specified by nlayer)
arc_layer=string [required]
    Arc layer
    Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name.
    Default: 1
arc_type=string [,string,...] [required]
    Arc type
    Input feature type
    Allowed values: line, boundary
    Default: line,boundary
node_layer=string [required]
    Node layer (used for cities)
    Default: 2
arc_column=string
    Arc forward/both direction(s) cost column (number)
    EXPERIMENTAL: Arc backward direction cost column (number)
turn_layer=string
    Layer with turntable
    Relevant only with -t flag
    Default: 3
    Layer with unique categories used in turntable
    Default: 4
sequence=name
    Name for output file holding node sequence ("-" for stdout)
-t
    Use turntable
-g
    Use geodesic calculation for longitude-latitude projects
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
input : str, required
    Used as: input, vector, name
output : str, required
    Used as: output, vector, name
center_cats : str, required
    Category values
    Used as: input, cats, range
arc_layer : str, required
    Arc layer
    Used as: input, layer
    Default: 1
arc_type : str | list[str], required
    Arc type
    Input feature type
node_layer : str, required
    Default: 2
arc_column : str, optional
arc_backward_column : str, optional
turn_layer : str, optional
    Default: 3
turn_cat_layer : str, optional
    Default: 4
sequence : str, optional
    Used as: output, file, name
flags : str, optional
    Allowed values: t, g
    t
        Use turntable
    g
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
    Category values
    Arc layer
    Default: 1
    Arc type
    Input feature type
    Default: 2
    Default: 3
    Default: 4
    t
        Use turntable
    g
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
v.net.salesman calculates the optimal route to visit nodes on a vector network.
Costs may be either line lengths or attributes saved in a database
table. These attribute values are taken as costs of whole segments, not
as costs to traverse a length unit (e.g. meter) of the segment. For
example, if the speed limit is 100 km / h, the cost to traverse a 10 km
long road segment must be calculated as
length / speed = 10 km / (100 km/h) = 0.1 h.
Supported are cost assignments for arcs, and also different costs for
both directions of a vector line. For areas, costs will be calculated
along boundary lines.
The input vector needs to be prepared with v.net operation=connect in order to connect points representing center nodes to the network.
Points specified by category must be exactly on network nodes, and the input vector map needs to be prepared with v.net operation=connect.
The flag -t enables turntable support. This flag requires additional parameters, turn_layer and turn_cat_layer, that are otherwise ignored. The turntable allows to model e.g. traffic code, where some turns may be prohibited. This means that the input layer is expanded by turntable with costs of every possible turn on any possible node (intersection) in both directions. Turntable can be created by the v.net module. For more information about turns in the vector network analyses see wiki page.
NOTES
Arcs can be closed using cost = -1. Turns support: The costs of turns on visiting nodes are not taken in account.
EXAMPLE
Traveling salesman for 6 digitized nodes (Spearfish):
Shortest path, along unimproved roads:
Fastest path, along highways:
Searching for the shortest path using distance and the fastest path using traveling time according to the speed limits of different road types:
# Spearfish
g.copy vect=roads,myroads
# we have 6 locations to visit on our trip
echo "1|601653.5|4922869.2|a
2|608284|4923776.6|b
3|601845|4914981.9|c
4|596270|4917456.3|d
5|593330.8|4924096.6|e
6|598005.5|4921439.2|f" | v.in.ascii in=- cat=1 x=2 y=3 out=centers col="cat integer, \
                         east double precision, north double precision, label varchar(43)"
# verify data preparation
v.db.select centers
v.category centers op=report
# type       count        min        max
# point          6          1          6
# create lines map connecting points to network (on layer 2)
v.net myroads points=centers out=myroads_net op=connect thresh=500
v.category myroads_net op=report
# Layer / table: 1 / myroads_net
# line         837          1          5
# Layer: 2
# point          6          1          5
# find the shortest path
v.net.salesman myroads_net center_cats=1-6 out=mysalesman_distance
# set up costs as traveling time
# create unique categories for each road in layer 3
v.category in=myroads_net out=myroads_net_time opt=add cat=1 layer=3 type=line
# add new table for layer 3
v.db.addtable myroads_net_time layer=3 col="cat integer,label varchar(43),length double precision,speed double precision,cost double precision,bcost double precision"
# copy road type to layer 3
v.to.db myroads_net_time layer=3 qlayer=1 opt=query qcolumn=label columns=label
# upload road length in miles
v.to.db myroads_net_time layer=3 type=line option=length col=length unit=miles
# set speed limits in miles / hour
v.db.update myroads_net_time layer=3 col=speed val="5.0"
v.db.update myroads_net_time layer=3 col=speed val="75.0" where="label='interstate'"
v.db.update myroads_net_time layer=3 col=speed val="75.0" where="label='primary highway, hard surface'"
v.db.update myroads_net_time layer=3 col=speed val="50.0" where="label='secondary highway, hard surface'"
v.db.update myroads_net_time layer=3 col=speed val="25.0" where="label='light-duty road, improved surface'"
v.db.update myroads_net_time layer=3 col=speed val="5.0" where="label='unimproved road'"
# define traveling costs as traveling time in minutes:
# set forward costs
v.db.update myroads_net_time layer=3 col=cost val="length / speed * 60"
# set backward costs
v.db.update myroads_net_time layer=3 col=bcost val="length / speed * 60"
# find the fastest path
v.net.salesman myroads_net_time arc_layer=3 node_layer=2 arc_column=cost arc_backward_column=bcost center_cats=1-6 out=mysalesman_time
To display the result, run for example:
# Display the results
g.region vector=myroads_net
# shortest path
d.mon x0
d.vect myroads_net
d.vect centers -c icon=basic/triangle
d.vect mysalesman_distance col=green width=2
d.font Vera
d.vect centers col=red disp=attr attrcol=label lsize=12
# fastest path
d.mon x1
d.vect myroads_net
d.vect mysalesman_time col=green width=2
d.font Vera
SEE ALSO
d.path, v.net, v.net.alloc, v.net.iso, v.net.path, v.net.steiner
AUTHORS
Radim Blazek, ITC-Irst, Trento, Italy
Markus Metz
Documentation: Markus Neteler, Markus Metz
TURNS SUPPORT
The turns support was implemented as part of GRASS GIS turns cost
project at Czech Technical University in Prague, Czech Republic.
Eliska Kyzlikova, Stepan Turek, Lukas Bocan and Viera Bejdova
participated in the project.
Implementation: Stepan Turek
Documentation: Lukas Bocan
Mentor: Martin Landa
SOURCE CODE
Available at: v.net.salesman source code
(history)
Latest change: Thursday Feb 13 14:10:24 2025 in commit c0fe7d7
