NAME
v.boxplot - Draws a boxplot of values from a specified attribute column in a vector dataset, with an optional grouping based on categories in another column.
KEYWORDS
display,
vector,
plot,
histogram,
boxplot
SYNOPSIS
v.boxplot
v.boxplot --help
v.boxplot [-hnrgo] map=name [layer=string] column=name [group_by=name] [where=sql_query] [output=name] [plot_dimensions=string] [dpi=integer] [fontsize=integer] [order=string] [axis_limits=string] [bx_color=name] [bx_blcolor=name] [bx_width=float] [bx_lw=float] [median_lw=float] [median_color=name] [flier_marker=string] [flier_size=float] [flier_color=name] [map_outliers=name] [overlap_basis=string] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
- -h
- horizontal boxplot(s)
- Draw the boxplot horizontal
- -n
- notch
- Draw boxplot(s) with notch
- -r
- Rotate labels
- rotate x-axis labels
- -g
- Add grid lines
- Add grid lines
- -o
- Include outliers
- Draw boxplot(s) with outliers
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- map=name [required]
- Name of vector map
- Or data source for direct OGR access
- layer=string
- Layer number or name
- Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name.
- Default: 1
- column=name [required]
- Attribute column value to be plotted
- group_by=name
- Attribute column with categories to group the data by
- where=sql_query
- WHERE conditions of SQL statement without 'where' keyword
- Example: income < 1000 and population >= 10000
- output=name
- Name of output image file
- Name for output file
- plot_dimensions=string
- Plot dimensions
- Dimensions (width,height) of the figure in inches
- dpi=integer
- DPI
- resolution of plot
- Default: 100
- fontsize=integer
- Font size
- Default font size
- Default: 10
- order=string
- Sort boxplots
- Sort boxplots based on their median values
- Options: descending, ascending
- axis_limits=string
- Limit value axis [min,max]
- min and max value of y-axis, or x-axis if -h flag is set)
- bx_color=name
- Color of the boxplots
- Color of boxplots
- Default: white
- bx_blcolor=name
- Color of the borders of the boxplots
- Color of the borderlines of the boxplots
- Default: black
- bx_width=float
- Boxplot width
- The width of the boxplots (0,1])
- Options: 0.1-1
- Default: 0.75
- bx_lw=float
- boxplot linewidth
- The boxplots border, whisker and cap line width
- Default: 1
- median_lw=float
- width of the boxplot median line
- Default: 1.1
- median_color=name
- Color of the boxplot median line
- Color of median
- Default: orange
- flier_marker=string
- Flier marker
- Set flier marker (see https://matplotlib.org/stable/api/markers_api.html for options)
- Default: o
- flier_size=float
- Flier size
- Set the flier size
- Default: 2
- flier_color=name
- Flier color
- Set the flier color
- Default: black
- map_outliers=name
- Vector map with the outliers
- Create a vector map with the outlier features, classified by how many other groups they overlap with (n_overlap), on which side and how far they lie from their own group (side, iqr_dist), with matching colors in a GRASSRGB column.
- overlap_basis=string
- Overlap basis
- Range of the other groups an outlier is checked against to count overlaps: whisker (within the other group's whiskers/fences) or box (within its interquartile box)
- Options: whisker, box
- Default: whisker
The v.boxplot module draws a boxplot of the values in a vector
map attribute column. Users can use the where option to
select a subset of the attribute table. Values in the column can also be grouped
according to the categories in another column (group_by), creating
separate boxplots for each group.
Options to customize the appearance of the plot include rotating the plot and
x-axis labels, adding notches, removing outliers, and defining the colors of
various boxplot components. By default, the resulting plot is displayed on the
screen. However, users can save the plot to a file by specifying the desired
width, height, and resolution. The format of the saved file is determined by the
provided file extension. For example, if plot_output = outputfile.png,
the plot will be saved as a PNG file.
Setting outliers_map creates a vector map with only features whose
column value is a boxplot outlier. With group_by, outliers are computed
separately per group. The output keeps the original attributes and adds:
- side: low or high outlier.
- iqr_dist: signed distance beyond the relevant fence, in IQR units.
- n_overlap: number of other groups whose value range contains the outlier.
- GRASSRGB: color string; high outliers are red, low outliers blue. More
exceptional values are darker and more saturated.
The overlap_basis defines the comparison range. With whisker, outliers are
compared with other groups non-outlier range, between fences. With box,
they are only compared with other groups interquartile range, Q1-Q3.
The outlier map is created in addition to the plot; both are derived from the
same selection, so the exported outliers always match those shown in the figure.
If the selection contains no outliers, the map is not created and a warning is
issued.
Use the vector layer
schools_wake from the
NC sample
dataset to create boxplots of the core capacity of schools in
Wake County, North Carolina. Use the
Where clause to exclude
all records with no data. Use the
-o flag to draw outliers.
v.boxplot -n -o map=schools_wake column=CORECAPACI where="CORECAPACI >0"
Figure 1: Boxplot of
core capacity of schools in Wake County.
NC sample dataset to
create boxplots of the core capacity of the schools in Wake County,
North Carolina, grouped by city. Use the
Where clause to
exclude all records with missing data. Use the
-o flag to draw
outliers.
v.boxplot -h -o map=schools_wake column=CORECAPACI where="CORECAPACI >0" group_by=ADDRCITY order=ascending
Figure 2: Boxplot of core capacity of schools
in Wake County, grouped by city.
v.scatterplot,
d.vect.colhist,
r.boxplot,
r.series.boxplot,
t.rast.boxplot,
r.scatterplot
r3.scatterplot
Paulo van Breugel,
HAS green academy,
Innovative
Biomonitoring research group,
Climate-robust
Landscapes research group
SOURCE CODE
Available at:
v.boxplot source code
(history)
Latest change: Thursday May 28 23:11:58 2026 in commit: 1b9adc940f57eb078fd7dd727423679ada24b232
Main index |
Vector index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2026
GRASS Development Team,
GRASS 8.5.1dev Reference Manual
