r.out.maxent_swd
Exports map data as input to MaxEnt in SWD format
r.out.maxent_swd [-z] [alias_input=name] [env_maps=name [,name,...]] [alias_names=string] [bgr_output=name] [alias_output=name] [bgr_mask=name] [species_masks=name [,name,...]] [species_output=name] [species_names=string] [null_value=integer] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh
r.out.maxent_swd alias_input=name
grass.script.run_command("r.out.maxent_swd", alias_input=None, env_maps=None, alias_names=None, bgr_output=None, alias_output=None, bgr_mask=None, species_masks=None, species_output=None, species_names=None, null_value=-9999, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
gs.run_command("r.out.maxent_swd", alias_input="name")
grass.tools.Tools.r_out_maxent_swd(alias_input=None, env_maps=None, alias_names=None, bgr_output=None, alias_output=None, bgr_mask=None, species_masks=None, species_output=None, species_names=None, null_value=-9999, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
tools = Tools()
tools.r_out_maxent_swd(alias_input="name")
Parameters
alias_input=name
File containg map and alias name(s) for environmental parameter(s)
Environmental parameter map(s)
alias_names=string
Alias names for environmental parameter map(s)
bgr_output=name
Output SWD file for the environmental data of the background landscape
alias_output=name
CSV-like output file with alias names in first column and map names in second column, separated by comma
bgr_mask=name
Map to be used as mask for the background landscape
Raster map(s) of specie occurence
species_output=name
Output SWD file for the specie(s) related environmental data
Alias-name(s) for species to be used in MaxEnt SWD file instead of map names, separated by comma (default: map names).
null_value=integer
Integer representing NO DATA cell value (default: -9999)
Default: -9999
-z
Zoom computational region to species data (may speed up processing)
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
alias_input : str, optional
Used as: input, file, name
env_maps : str | list[str], optional
Used as: input, raster, name
alias_names : str, optional
bgr_output : str, optional
Used as: output, file, name
alias_output : str, optional
bgr_mask : str, optional
species_masks : str | list[str], optional
species_output : str, optional
species_names : str, optional
null_value : int, optional
Default: -9999
flags : str, optional
Allowed values: z
z
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
alias_input : str | io.StringIO, optional
bgr_mask : str | np.ndarray, optional
Default: -9999
Allowed values: z
z
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
The script is intended to produce a set of SWD files as input to MaxEnt >= 3.3.3e using r.stats.
The SWD file format is a simple CSV-like file file format as described
in Elith et al. 2011. Generally it looks like:
specie_name,X,Y,parameter_1,parameter_2,...
csv
your_species,1.1,1.1,2,4.7,...
The first column always contains the name of the species, followed by two columns for the X- and Y-coordinates. Then each column represents one environmental parameter. In contrast to r.stats only integer values are accepted to represent NO DATA.
A background SWD file is always produced while species output can be omitted.
Multiple species can be processed, but each has to be in an individual raster map. Map names of the maps containing the environmental parameters can be replaced by short names, which should be used in MaxEnt >= 3.3.3.e.
Results from MaxEnt can either be imported using r.in.xyz or calculated from MaxEnt lambdas file using the r.maxent.lambdas.
SEE ALSO
r.stats, r.what, r.in.xyz,, r.maxent.lambdas
- Steven J. Phillips, Miroslav Dudík, Robert E. Schapire. 2020: Maxent software for modeling species niches and distributions (Version 3.4.1). Available from url: https://biodiversityinformatics.amnh.org/open_source/maxent and https://github.com/mrmaxent/Maxent
- Steven J. Phillips, Miroslav Dudík, Robert E. Schapire. 2004: A maximum entropy approach to species distribution modeling. In Proceedings of the Twenty-First International Conference on Machine Learning, pages 655-662, 2004.
- Steven J. Phillips, Robert P. Anderson, Robert E. Schapire. 2006: Maximum entropy modeling of species geographic distributions. Ecological Modelling, 190:231-259, 2006.
- Jane Elith, Steven J. Phillips, Trevor Hastie, Miroslav Dudík, Yung En Chee, Colin J. Yates. 2011: A statistical explanation of MaxEnt for ecologists. Diversity and Distributions, 17:43-57, 2011.
AUTHOR
Stefan Blumentrath, Norwegian Institute for Nature Research (NINA), https://www.nina.no
SOURCE CODE
Available at: r.out.maxent_swd source code
(history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
