t.rast.import.netcdf
Import netCDF files that adhere to the CF convention as STRDS.
t.rast.import.netcdf [-airlfeo] input=Input file(s) ("-" = stdin) [semantic_labels=Input file with configuration for semantic labels ("-" = stdin)] [output=name] [end_time=string] [start_time=string] [temporal_relations=string [,string,...]] [resample=string] [print=string] [color=style] [memory=memory in MB] [default_crs=Default CRS (EPSG code)] [nprocs=integer] [separator=character] [nodata=Source nodata [,Source nodata,...]] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh
t.rast.import.netcdf input=Input file(s) ("-" = stdin) print=extended
grass.script.run_command("t.rast.import.netcdf", input, semantic_labels=None, output=None, end_time=None, start_time=None, temporal_relations="equal,during,contains,overlaps,overlapped,starts,started,finishes,finished", resample="nearest", print=None, color="viridis", memory=300, default_crs=None, nprocs=1, separator="pipe", nodata=None, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
gs.run_command("t.rast.import.netcdf", input="Input file(s) ("-" = stdin)", print="extended")
grass.tools.Tools.t_rast_import_netcdf(input, semantic_labels=None, output=None, end_time=None, start_time=None, temporal_relations="equal,during,contains,overlaps,overlapped,starts,started,finishes,finished", resample="nearest", print=None, color="viridis", memory=300, default_crs=None, nprocs=1, separator="pipe", nodata=None, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
tools = Tools()
tools.t_rast_import_netcdf(input="Input file(s) ("-" = stdin)", print="extended")
Parameters
input=Input file(s) ("-" = stdin) [required]
URL or name of input netcdf-file ("-" = stdin)
File with mapping of variables or subdatasets to semantic labels
output=name
Name of the output space time raster dataset
end_time=string
Latest timestamp of temporal extent to include in the output
Timestamp of format "YYYY-MM-DD HH:MM:SS"
start_time=string
Earliest timestamp of temporal extent to include in the output
Allowed temporal relation for temporal filtering
Allowed temporal relation between time dimension in the netCDF file and temporal window defined by start_time and end_time
Allowed values: equal, during, contains, overlaps, overlapped, starts, started, finishes, finished
Default: equal,during,contains,overlaps,overlapped,starts,started,finishes,finished
resample=string
Resampling method when data is reprojected
Allowed values: nearest, bilinear, bicubic, cubicspline, lanczos, average, mode, max, min, med, Q1, Q3
Default: nearest
print=string
Print metadata and exit
Allowed values: extended, grass
color=style
Color table to assign to imported datasets
Allowed values: aspect, aspectcolr, bcyr, bgyr, blues, byg, byr, celsius, corine, curvature, differences, elevation, etopo2, evi, fahrenheit, forest_cover, gdd, grass, greens, grey, grey.eq, grey.log, grey1.0, grey255, gyr, haxby, inferno, kelvin, magma, ndvi, ndwi, nlcd, oranges, plasma, population, population_dens, precipitation, precipitation_daily, precipitation_monthly, rainbow, ramp, random, reds, roygbiv, rstcurv, ryb, ryg, sepia, slope, soilmoisture, srtm, srtm_percent, srtm_plus, terrain, viridis, water, wave
Default: viridis
aspect: aspect oriented grey colors [range: map values]
aspectcolr: aspect oriented rainbow colors [range: 0 to 360]
bcyr: blue through cyan through yellow to red [range: map values]
bgyr: blue through green through yellow to red [range: map values]
blues: white to blue [range: map values]
byg: blue through yellow to green [range: map values]
byr: blue through yellow to red [range: map values]
celsius: blue to red for degree Celsius temperature [range: -80 to 80]
corine: EU Corine land cover colors [range: 111 to 995]
curvature: for terrain curvatures (from v.surf.rst and r.slope.aspect) [range: map values]
differences: differences oriented colors [range: map values]
elevation: maps relative ranges of raster values to elevation color ramp [range: map values]
etopo2: colors for ETOPO2 worldwide bathymetry/topography [range: -11000 to 8850]
evi: enhanced vegetative index colors [range: -1 to 1]
fahrenheit: blue to red for Fahrenheit temperature [range: -112 to 176]
forest_cover: percentage of forest cover [range: 0 to 100]
gdd: accumulated growing degree days [range: 0 to 6000]
grass: GRASS green (perceptually uniform) [range: map values]
greens: white to green [range: map values]
grey: grey scale [range: map values]
grey.eq: histogram-equalized grey scale [range: map values]
grey.log: histogram logarithmic transformed grey scale [range: map values]
grey1.0: grey scale for raster values between 0.0-1.0 [range: 0 to 1]
grey255: grey scale for raster values between 0-255 [range: 0 to 255]
gyr: green through yellow to red [range: map values]
haxby: relative colors for bathymetry or topography [range: map values]
inferno: perceptually uniform sequential color table inferno [range: map values]
kelvin: blue to red for temperature in Kelvin scale [range: 193.15 to 353.15]
magma: perceptually uniform sequential color table magma [range: map values]
ndvi: Normalized Difference Vegetation Index colors [range: -1 to 1]
ndwi: Normalized Difference Water Index colors [range: -200 to 200]
nlcd: US National Land Cover Dataset colors [range: 0 to 95]
oranges: white to orange [range: map values]
plasma: perceptually uniform sequential color table plasma [range: map values]
population: color table covering human population classification breaks [range: 0 to 2e+09]
population_dens: color table covering human population density classification breaks [range: 0 to 1e+09]
precipitation: precipitation color table (0..2000mm) [range: 0 to 7000]
precipitation_daily: precipitation color table (0..1000mm) [range: 0 to 10000]
precipitation_monthly: precipitation color table (0..1000mm) [range: 0 to 1000]
rainbow: rainbow color table [range: map values]
ramp: color ramp [range: map values]
random: random color table [range: map values]
reds: white to red [range: map values]
roygbiv: [range: map values]
rstcurv: terrain curvature (from r.resamp.rst) [range: map values]
ryb: red through yellow to blue [range: map values]
ryg: red through yellow to green [range: map values]
sepia: yellowish-brown through to white [range: map values]
slope: r.slope.aspect-type slope colors for raster values 0-90 [range: 0 to 90]
soilmoisture: soilmoisture color table (0.0-1.0) [range: 0 to 1]
srtm: color palette for Shuttle Radar Topography Mission elevation [range: -11000 to 8850]
srtm_percent: color palette for Shuttle Radar Topography Mission using relative elevation [range: map values]
srtm_plus: color palette for Shuttle Radar Topography Mission elevation (with seafloor colors) [range: -11000 to 8850]
terrain: global elevation color table covering -11000 to +8850m [range: -11000 to 8850]
viridis: perceptually uniform sequential color table viridis [range: map values]
water: water depth [range: map values]
wave: color wave [range: map values]
memory=memory in MB
Maximum memory to be used (in MB)
Cache size for raster rows
Default: 300
Default Coordinate Reference System (EPSG code)
EPSG code to assume if a (sub-) dataset has no CRS defined
nprocs=integer
Default: 1
separator=character
Field separator
Special characters: pipe, comma, space, tab, newline
Default: pipe
Comma separated list of values representing nodata in the input dataset
-a
Append to STRDS
-i
Allow incomplete CF-dimensions (XY instead of XYT)
-r
Import only within current region
-l
Link the raster files using r.external
-f
Link the raster files in a fast way, without reading metadata using r.external
-e
Extend location extents based on new dataset
-o
Override projection check (use current location's projection)
Assume that the dataset has same projection as the current location
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
input : str, required
Used as: input, file, Input file(s) ("-" = stdin)
semantic_labels : str, optional
Used as: input, file, Input file with configuration for semantic labels ("-" = stdin)
output : str, optional
Used as: output, strds, name
end_time : str, optional
start_time : str, optional
temporal_relations : str | list[str], optional
resample : str, optional
Default: nearest
print : str, optional
color : str, optional
Used as: input, colortable, style
Default: viridis
memory : int, optional
Used as: memory in MB
Default: 300
default_crs : int, optional
Used as: Default CRS (EPSG code)
nprocs : int, optional
Default: 1
separator : str, optional
Field separator
Used as: input, separator, character
Default: pipe
nodata : str | list[str], optional
Used as: Source nodata
flags : str, optional
Allowed values: a, i, r, l, f, e, o
a
Append to STRDS
i
r
l
f
e
o
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
input : str | io.StringIO, required
semantic_labels : str | io.StringIO, optional
Default: nearest
Default: viridis
Default: 300
Default: 1
Field separator
Default: pipe
a
Append to STRDS
i
r
l
f
e
o
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
t.rast.import.netcdf imports content of one or more NetCDF files into a GRASS GIS Space Time Raster Dataset (STRDS). NetCDF files are expected to follow the CF-convention. Files not adhering to those standards may fail to import.
The Attribute Convention for Data Discovery (ACDD) that is related to the CF-Convention is partly supported. Datasets compliant with ACDD but not CF-Convention the i-flag may have to be used.
Input URL(s) to NetCDF files can be provided in the input option as either a file, with one URL to a dataset per line, a comma-separated list of URLs or a single URL. "-" causes input to be taken from stdin.
The module works for both local and remote data (e.g. on a Thredds Server). Data can be imported via r.in.gdal or linked with r.external.
t.rast.import.netcdf uses GDALs Virtual Raster format (VRT) if data's Coordinate Reference system differs from the one of the current location where they are supposed to be imported.
Reprojection on import is done using GDAL warp if necessary. In that case, users should be aware of the extent and resolution of the data to import and the current computational region. Import is limited to and aligned with the current computational region, if the r-flag is set. Otherwise, extent and resolution in the target CRS is guessed by GDAL. Import of global data to coordinate systems that do not support that extent will thus fail.
Starting with GRASS GIS version 8.0, different variables or subdatasets
in a NetCDF file can be imported as "semantic_label" into one STRDS. To
achieve this, a configuration file has to be provided in the
semantic_labels option. That configuration file maps subdatasets in
the NetCDF file to GRASS GIS semantic_labels. Each line in that file
must have the following format: input_netcdf_subdataset=grass_gis_semantic_label The equal sign = is
required. If a semantic_labels configuration file is provided, the
import of subdatasets is limited to those subdatasets listed in the
file. Hence, it can be used to filter variables of interest.
KNOWN ISSUES
The VRT format is also used when linking NetCDF data that contains subdatasets, as subdatasets are currently not supported in r.external.
Reading NetCDF files directly via HTTP protocol (like in the examples below) is currently not supported on MS Windows.
GDAL versions prior to 3.4.1 do not support reading NetCDF files directly via HTTP protocol on newer Linux kernels either. Please make sure to have at least GDAL version 3.4.1 on recent Linux systems. See posts on the GDAL-dev mailing list. for reference.
The Attribute Convention for Data Discovery (ACDD) is not yet fully supported, depending on the structure of the datasets, import may or may not work.
REQUIREMENTS
Support of semantic_labels is only available with GRASS GIS 8.0 or later. t.rast.import.netcdf uses the following non-standard Python modules:
EXAMPLES
Link Sentinel-2 scenes from the Norwegian Ground Segment
```sh
Choose Scenes to import (see also m.crawl.thredds module)
echo "https://nbstds.met.no/thredds/fileServer/NBS/S2A/2021/02/28/S2A_MSIL1C_20210228T103021_N0202_R108_T35WPU_20210228T201033_DTERRENGDATA.nc https://nbstds.met.no/thredds/fileServer/NBS/S2A/2021/02/28/S2A_MSIL1C_20210228T103021_N0202_R108_T32VNL_20210228T201033_DTERRENGDATA.nc" > nc.txt
Create a semantic_label configuration file
echo "B1=S2_1 B2=S2_2" > semantic_labels.conf
Import data (link NetCDF files without downloading them)
t.rast.import.netcdf -l input=nc.txt output=S2A semantic_labels=semantic_labels.conf \ memory=2048 nprocs=2 nodata="-1" ```
Import Norwegian Climate data
```sh
echo "tg=temperature_avg tn=temperature_min" > semantic_labels.conf
Import data within a selected time window
t.rast.import.netcdf output=SeNorge semantic_labels=semantic_labels.conf \ memory=2048 nprocs=2 start_time="2020-08-01" end_time="2021-08-01" \ input=https://thredds.met.no/thredds/fileServer/senorge/seNorge_2018/Archive/seNorge2018_2020.nc ```
Append to STRDS from previous imports
```sh
Choose dataset to import (see also m.crawl.thredds module)
t.rast.import.netcdf output=SeNorge semantic_labels=semantic_labels.conf \ memory=2048 nprocs=2 -a start_time="2020-08-01" end_time="2021-08-01" \ input=https://thredds.met.no/thredds/fileServer/senorge/seNorge_2018/Archive/seNorge2018_2021.nc ```
Import ACDD but not CF-compliant dataset from SWOT
```sh
echo "wse=SWOT_wse wse_ucert=SWOT_wse_uncertainty" > semantic_labels.conf
t.rast.import.netcdf -i output=SWOT semantic_labels=semantic_labels.conf \ memory=2048 nprocs=2 \ input=./SWOT_L2_HR_Raster_100m_UTM33W_N_x_x_x_020_113_138F_20240824T163805_20240824T163826_PIC0_01.nc ```
TODO
- Capture and store extended metadata in a way that allows for filtering of relevant maps.
- Improve printing of metadata and file structure
- Support more options of Virtual Raster files (data type, ...)
SEE ALSO
t.rast.import, r3.out.netcdf, r.semantic_labels, i.bands_library, r.support, m.crawl.thredds
AUTHORS
Stefan Blumentrath, Oslo, Norway
SOURCE CODE
Available at: t.rast.import.netcdf source code
(history)
Latest change: Friday Feb 20 18:45:23 2026 in commit 97019d6
