v.civil
Generates a alignment for designing roads, channels, and ports in civil engineering
v.civil [-oecrpt] name=name [plan=string [,string,...]] [pkopt=string] [dtable=name] [mtable=name] [areaopt=string] [vert=string [,string,...]] [lpscale=integer] [lpopt=string] [lpoffset=string] [camber=string] [displrot=string] [trans=string [,string,...]] [ltscale=float] [ltopt1=string] [ltopt2=string] [ltoffset=string] [terr=string [,string,...]] [dem=raster dem] [actions=string [,string,...]] [pk_info=float] [topotools=string [,string,...]] [roundabout=string [,string,...]] [rround1=string] [rround2=string] [azround=string] [cround=string] [roundname=string] [add=string [,string,...]] [tab_type=string] [tab_subname=string] [pklist=string] [displline=string [,string,...]] [side=string] [ncol=integer] [sedist=string] [intersect=string [,string,...]] [plant1=map plant 1] [cat1=integer] [plant2=map plant 2] [cat2=integer] [dist1=string] [dist2=string] [radios=string] [intr=integer] [intc=integer] [startend=string] [backup=name] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh
v.civil name=name
grass.script.run_command("v.civil", name, plan="", pkopt="20,100,2,4", dtable=None, mtable=None, areaopt=None, vert="", lpscale=4, lpopt="2,20,1,20", lpoffset="0,0", camber="0", displrot="0,0", trans="", ltscale=2, ltopt1="1,20,2", ltopt2="10,10,10", ltoffset="0,0", terr="", dem=None, actions="", pk_info=0, topotools="", roundabout="", rround1=None, rround2=None, azround=None, cround=None, roundname=None, add="", tab_type=None, tab_subname=None, pklist=None, displline="", side=None, ncol=None, sedist=None, intersect="", plant1=None, cat1=1, plant2=None, cat2=1, dist1=None, dist2=None, radios=None, intr=1, intc=1, startend="0,-1", backup=None, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
gs.run_command("v.civil", name="name")
grass.tools.Tools.v_civil(name, plan="", pkopt="20,100,2,4", dtable=None, mtable=None, areaopt=None, vert="", lpscale=4, lpopt="2,20,1,20", lpoffset="0,0", camber="0", displrot="0,0", trans="", ltscale=2, ltopt1="1,20,2", ltopt2="10,10,10", ltoffset="0,0", terr="", dem=None, actions="", pk_info=0, topotools="", roundabout="", rround1=None, rround2=None, azround=None, cround=None, roundname=None, add="", tab_type=None, tab_subname=None, pklist=None, displline="", side=None, ncol=None, sedist=None, intersect="", plant1=None, cat1=1, plant2=None, cat2=1, dist1=None, dist2=None, radios=None, intr=1, intc=1, startend="0,-1", backup=None, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
tools = Tools()
tools.v_civil(name="name")
Parameters
name=name [required]
Name of input vector map
Name of road map
Plan options
Allowed values: plan, pks, displ, marks
pkopt=string
Pks marks options values. (npk,mpk,dist,m)
Default: 20,100,2,4
dtable=name
Other displaced table (Default all)
mtable=name
Other marks table (Default all)
areaopt=string
Pair of displaced lines for areas (1-2,2-5,5-6)
Vertical options
Allowed values: vert, profile
lpscale=integer
Long profile vertical scale (V/H, V/1)
Allowed values: 0-100
Default: 4
lpopt=string
Long profile values Longmark,distMark_x,distMark_y,DistGitarr.
Default: 2,20,1,20
lpoffset=string
Long profile offset from origin of region
Default: 0,0
camber=string
General camber
Default: 0
displrot=string
Displaced lines to rotate
Default: 0,0
Vertical options
Allowed values: trans, profiles
ltscale=float
Cross section vertical scale (V/H, V/1)
Default: 2
ltopt1=string
Cross section options values Longmark,distMark_x,distMark_y.
Default: 1,20,2
ltopt2=string
Trans section options values for nrows,distTP_x,distTP_y.
Default: 10,10,10
ltoffset=string
Trans sections profile offset from origin of region
Default: 0,0
Terrain options
Allowed values: slopes, sareas, topo
dem=raster dem
Name of DEM raster
Points tools
Allowed values: uppoints, pnt_info
pk_info=float
PK
Default: 0
Triangulate and curved
Allowed values: triangle, delaunay, curved, cut_hull
Roundabout tools
Allowed values: roundabout
rround1=string
Minus radio for roundabout edge
rround2=string
Mayor radio for roundabout edge
azround=string
Azimut for roundabout start point
cround=string
Center for roundabout
roundname=string
Name for roundabout
Add new table or add row to table
Allowed values: table, row
tab_type=string
Name of table for new table or to add row
To add new table only Displ or Marks table are supported
Allowed values: Vert, Displ, Trans, Terr, Marks
tab_subname=string
Table subname for new table or row or displ subname to add or del col
pklist=string
List of Pks
Add or del displaced line
Allowed values: add, del
side=string
left or right side of Displ
Allowed values: left, right
ncol=integer
Number of Displ to insert
sedist=string
start and end distance and height
Plan options
Allowed values: left1, right1, left2, right2, in, out, rounda, write
plant1=map plant 1
Name of first map plant
cat1=integer
Categorie of align
Default: 1
plant2=map plant 2
Name of second map plant
cat2=integer
Categorie of align
Default: 1
dist1=string
Displaced distances for aling 1
dist2=string
Displaced distances for aling 2
radios=string
Intersections radios
intr=integer
Interval in straights
Default: 1
intc=integer
Interval in curves
Default: 1
startend=string
start and end pks (last pk = -1)
Default: 0,-1
backup=name
Create backup file
-o
TopoTools
-e
TableTools
-c
CrossTools
-r
Run
-p
Update solution from polygon
-t
Update solution from table plan distances_
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
Name of road map
Used as: input, vector, name
plan : str | list[str], optional
Plan options
pkopt : str, optional
Default: 20,100,2,4
dtable : str, optional
Used as: input, dbtable, name
mtable : str, optional
areaopt : str, optional
vert : str | list[str], optional
Vertical options
lpscale : int, optional
Default: 4
lpopt : str, optional
Default: 2,20,1,20
lpoffset : str, optional
Default: 0,0
camber : str, optional
General camber
Default: 0
displrot : str, optional
Default: 0,0
trans : str | list[str], optional
Vertical options
ltscale : float, optional
Default: 2
ltopt1 : str, optional
Default: 1,20,2
ltopt2 : str, optional
Default: 10,10,10
ltoffset : str, optional
Default: 0,0
terr : str | list[str], optional
Terrain options
dem : str, optional
Name of DEM raster
Used as: input, raster, raster dem
actions : str | list[str], optional
Points tools
pk_info : float, optional
PK
Default: 0
topotools : str | list[str], optional
roundabout : str | list[str], optional
Roundabout tools
rround1 : str, optional
rround2 : str, optional
azround : str, optional
cround : str, optional
roundname : str, optional
Name for roundabout
add : str | list[str], optional
tab_type : str, optional
tab_subname : str, optional
pklist : str, optional
List of Pks
displline : str | list[str], optional
side : str, optional
ncol : int, optional
sedist : str, optional
intersect : str | list[str], optional
Plan options
plant1 : str, optional
Used as: input, vector, map plant 1
cat1 : int, optional
Categorie of align
Default: 1
plant2 : str, optional
Used as: input, vector, map plant 2
cat2 : int, optional
Categorie of align
Default: 1
dist1 : str, optional
dist2 : str, optional
radios : str, optional
intr : int, optional
Default: 1
intc : int, optional
Interval in curves
Default: 1
startend : str, optional
Default: 0,-1
backup : str, optional
Create backup file
Used as: output, file, name
flags : str, optional
Allowed values: o, e, c, r, p, t
o
TopoTools
e
TableTools
c
CrossTools
r
Run
p
t
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
Name of road map
Plan options
Default: 20,100,2,4
Vertical options
Default: 4
Default: 2,20,1,20
Default: 0,0
General camber
Default: 0
Default: 0,0
Vertical options
Default: 2
Default: 1,20,2
Default: 10,10,10
Default: 0,0
Terrain options
dem : str | np.ndarray, optional
Name of DEM raster
Points tools
PK
Default: 0
Roundabout tools
Name for roundabout
List of Pks
Plan options
Categorie of align
Default: 1
Categorie of align
Default: 1
Default: 1
Interval in curves
Default: 1
Default: 0,-1
Create backup file
o
TopoTools
e
TableTools
c
CrossTools
r
Run
p
t
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
v.civil.road generates a alignment for design roads, channels, ports...
USAGE
To run the program for the first time, a map with one horizontal polygon, is required.
There are three options: The flag -r for run the program, The flag -p Update solution from polygon (if you modific the polygon), The flag -t Update solution from table plan (walk with dc_ and lr_)
The other options are described below.
Plan
plan write the horizontal alignment.
pks write pk marks in horizontal.
displ write the displaced platform lines in horizontal.
marks write the marks in horizontal.
pkopt define the distance between normal marks (npk), distance between principal marks (mpk), longitude of normal marks and longitude of principal marks.
areaopt write the areas defined with pairs of displaced lines.
Vertical
vert write the vertical alignment in horizontal.
profile write longitudinal profile map.
With the option LPScale, the vertical scale of the longitudinal profile can be given.
The LPopt option give the longitude of marks, distance between marks in axis x and y, and distance between lines of the guitar.
Cross
cross write cross section in horizontal
sections write cross sections map.
With the option LTScale, the vertical scale of the longitudinal profile can be given.
The LTopt option give the longitude of marks, distance between marks in axis x and y, and distance between lines of the guitar.
The LTopt2 option give the number of rows of cross-section to display, distance between cross-section in axis x and y.
Terrain
slopes flag write the slope soil lines calculated with the last displaced lines (perpendicular to the central axis).
sareas write the areas map with slope soil lines and the last displaced lines in horizontal.
tri write points, lines and hull area map.
Tools
The flag -a add a new table. Displ or Marks.
The flag -i insert a rows in table. List of pks for each row.
The flag -n add a new displ line, ei, a new column in displ table. You must give a start and end distances and height. And number of column and side to insert.
The flag -d del a displ line, ei, a column in displ table. A number of column and side is required.
Tables
We have six parts: plant, vertical, displaced, terrain, tranversal and marks.
The tables stored in the polygon map are:
Layer 1
Created with only cat column (if not exist), is for free use to add columns with information of the road.
Layer 2
"NameRoad"_Plan, for insert the parameters of the horizontal alignment. This layer have all vertices and nodes of the horizontal polygon. No more points can be added to this layer with the insert point option.
The columns are:
radio: radio of curve
+ for clockwise
- for anticlockwise
a_in: Parameter A of input Clothoid
a_out: Parameter A of output Clothoid
widening: Widening of curve (where this widening is growing in the clothoid, only in mode exact)
superelev: Parameter A of input Clothoid
dc_: longitude of curve. For use with flag -t
lr_: longitude of straight. For use with flag -t
Layer 3
"NameRoad"_Vert, for insert the parameters of the vertical alignment.This layer are created with the first an last vertices of the horizontal polygon. New point can be added by the flag 'e' TableTools option, or with edit gui. The added points, are inserted in the central axis referencing by pk.
The columns are:
- pk: kilometric point of the central axis
- elev: Elevation of the vertice of the vertical alignment
- kv: Parameter Kv of the vertical alignment
- l: Leng of parabolic curve (no yet implemented)
- B: Height of vertice of vertical polygon to the parabolic curve (no yet implemented)
Layer 4
"NameRoad"_Displ, for insert the parameters of the platform. This layer are created with the first an last vertices of the horizontal polygon. New point can be added by the flag 'e' TableTools option, or with edit gui. The added points, are inserted in the central axis referencing by pk.
The columns for editing by the user are:
- sec_left, sec_right: For defining left and right platform lines (distance and height to the central axis), separated by ";"
- type_left, type_right: Types of left and right lines (types are: l,e,r,0). You can enter the type of multiple lines separated by ";" l: linear approximation between definition points. e: displaced lines, mode exact. c: ellipse between definition points. rR,A: circle between definition points ((x-A)^2+y^2=R^2))
Between two points, if the second input distance equal zero, the line will be stopped. If the second input distance equal -1, this point will not be processed and the next one will be considered.
Layer 5
"NameRoad"_Terr, for insert the parameters for slopes. This layer are created with the first an last vertices of the horizontal polygon. New point can be added by the flag 'e' TableTools option, or with edit gui. The added points, are inserted in the central axis referencing by pk.
- cut_left: Cut slope left
- cut_right: Cut slope right
- fill_left: Fill slope left
- fill_right: Fill slope right
Layer 6
"NameRoad"_Trans, for insert the parameters of transects to the central axis. This layer are created with the first an last vertices of the horizontal polygon. New point can be added by the flag 'e' TableTools option, or with edit gui. The added points, are inserted in the central axis referencing by pk.
- dist_left,dist_right: Distance left and right from the central axis
- npk: Distance between trans
Layer 7
"NameRoad"_Marks, for insert the parameters of Marks. This layer are created with the first an last vertex of the horizontal polygon. New point can be added by the flag 'e' TableTools option, or with edit gui. The added points, are inserted in the central axis referencing by pk.
- dist: distance left and right from the central axis
- elev: Elevation left and right from the central axis
- azi: 1 for azimuth of the point of the road or -1
- name: Name of mark
- cod: Code of mark
Example
This example is done in the North Carolina data set.
At the end of this example, there is a backup that can be executed to play with this example.
The example start creating a closed polygon with the editor, in a created map named Circuit.
After that, run the next command to get all tables in the map Circuit
sh
v.road -r name=Circuit
Plant
For each vertex of the polygon we define a radio and in and out clothoids. So we can write the plant and pks maps.
sh
v.road -r name=Circuit plan=plan,pks
And we obtain the map Circuit__Plant and Circuit__Pks, and their tables.
If we move some vertex of polygon we must run with the flag 'p' to update the road.
If we change some values of columns 'dc_' (long of circle) or 'lr_' (long of straight), or fill the last line (with 'dc_' and 'lr_' too, a new vertex are inserted and a new line) we must run with the flag 't' to update the road.
The distance between points of each alignments is of 1 meters by default, but this can be changed in the Interval in straights and Interval in curves options.
Vertical option
At first, we have only the nodes of polygon, and if we set elev we will obtain a straight with slope. To get more vertices we have to add new rows to this table with tabletools giving the pk of the vertex.
And now we have to set the elevation of those vertices and the kv parameter.
Now choose vertical option to get the vertical map in horizontal and the longitudinal profile, and give a DEM in the terrain option.
sh
v.road -r name=Circuit vert=vert,profile dem=elev_lid792_1m
And we obtain the map Circuit__Vertical and Circuit__LongProfile , and their tables.
Displaced
For first time, this table have two rows, who are the nodes of the polygon, and for that the first and the last points of the central axis.
The displaced lines are defined in sec_left,sec_right columns with a list separated with ";", starting from left to right in each side of the central axis. Each displaced line is defined with distance to the central axis and height to the central axis (d,h).
The mode to calculate the displaced lines is defined in the type_left,type_right columns,for each line separated by ";".
In this example we are going to define two displaced lines in the left side to the central axis and two for right side with slope 2% to out.
The platform lines define, the lanes of a road, the platform limits, ... Those lines can be parallel to the central axis of a road (or not). If it's so, we need to know that the parallel to a clothoid is not a clothoid. Then we have two ways to do the platform lines.
In the first way, mode exact "e", we need to calculate a new displaced central axis, e.i., a parallel to the polygon not to the central axis. The new alignment or displaced line created within the new polygon have new clothoids for the transitions. To run this mode, the first and the last points, of a section of the road, must have the same displaced distance.
The widening parameter of the section above, only will be calculate in this mode, because the widening growing in the clothoid, then is applied only to the displaced lines calculated with clothoid.
The second way, mode lineal "l", we calculate the perpendicular displaced distance to each point of the central axis, to obtain a parallel to it, where the transitions won't be clothoids. Then we can't know where are the tangents of transitions. But in this mode, the displaced distance for the first and the last points don't have to be the same in a section of the road. A lineal variation will be done between those points.
For this example, the first and last are defined as lineal and the rest are in mode exact.
Into this second way, the variation don't have to be only lineal. We can define a circumference in the displaced line with the option "rR,A".
sh
v.road -r name=Circuit plan=displ
And we obtain the map Circuit__Displaced, and their tables.
With distance to the central axis and height of the lines we can obtain different forms, that we'll see in the cross sections.
Now we can add new lines by hand or with TableTools option.
sh
v.road -e name=Circuit displline=add side=left ncol=3 sedist="10 -0.2; 10 -0.2"
v.road -e name=Circuit displline=add side=right ncol=3 sedist="10 -0.2; 10 -0.2"
And add new points. We are going to cut the last line in pk 900 and 1700.
sh
v.road -e name=Circuit@road add=row tab_type=Displ pklist=876,900,1074,1690,1700,1811
Mode exact "e" in the first two lines, without widening and with widening set to 0.2.
Terr
The cut/fill are calculated with the first displaced line of the left side and the last displaced line of the right side, and with the slope given in the columns cut_left, cut_right, fill_left, fill_right.
We can generate points of the different alignments, breaklines and a hull of all points.
sh
v.road -r name=Circuit terr=slopes,sareas,topo dem=elev_lid792_1m
And we obtain the map Circuit__Slopes, Circuit__Slopes_Areas, Circuit__Topo and Circuit__Topo_Hull, and their tables.
Transversal
In this table where we are going to define transversals 2D lines to the central axis, to obtain later, the cross sections.
This lines contains the cutoff with the displaced lines.
When this table is created, have two rows, who are the first and the last points of the central axis.
In the columns dist_left, dist_right we can define the distance left and right to the central axis and in the column npk the distance between lines.
We can obtain the transversal profiles selecting it too.
sh
v.road -r name=Circuit trans=trans,profiles dem=elev_lid792_1m
And we obtain the map Circuit__Trans and Circuit__TransProfiles, and their tables.
Marks
We can define marks or road objects by pk.
TopoTools
With the Circuit_Topo map created, we can triangulate with triangle or delaunay, and obtain the curves.
In this example we must delete the points that cross the road, for a good triangulation. We can run this.
```sh v.edit map=Circuit__Topo type=point tool=delete ids=0-999999 where="pk > 876 AND pk < 1074" v.edit map=Circuit__Topo type=point tool=delete ids=0-999999 where="pk > 1690 AND pk < 1811"
db.execute sql="DELETE FROM Circuit__Topo WHERE pk > 876 and pk < 1074" db.execute sql="DELETE FROM Circuit__Topo WHERE pk > 1690 and pk < 1811" ```
And obtain the Circuit__Topo like this. The hull must be changed too.
sh
v.road -o name=Circuit dem=elev_lid792_1m topotools=delaunay,curved,cut_hull
And we obtain the map Circuit__Topo_Tin and Circuit__Topo_Curves, and their tables.
Backup
After run the backup you can run this to obtain all maps.
sh
v.road -r name=Circuit plan=plan,pks,displ,marks vert=vert,profile trans=trans,profiles terr=slopes,sareas,topo dem=elev_lid792_1m
```sh echo "L 15 1 638602.453907 220281.587467 638872.438983 220266.927644 638731.321851 220395.256912 638781.230311 220495.669832 638890.64791 220489.728605 638750.420421 220565.326292 638662.05161 220298.095029 638632.866458 220535.678384 638483.222668 220543.750924 638406.451001 220388.023737 638502.195923 220398.284828 638721.795144 220655.135048 638656.193203 220404.828666 638268.15133 220299.739643 638602.453907 220281.587467 1 1 P 1 1 638602.453907 220281.587467 2 1 P 1 1 638872.438983 220266.927644 2 2 P 1 1 638731.321851 220395.256912 2 3 P 1 1 638781.230311 220495.669832 2 4 P 1 1 638890.64791 220489.728605 2 5 P 1 1 638750.420421 220565.326292 2 6 P 1 1 638662.05161 220298.095029 2 7 P 1 1 638632.866458 220535.678384 2 8 P 1 1 638483.222668 220543.750924 2 9 P 1 1 638406.451001 220388.023737 2 10 P 1 1 638502.195923 220398.284828 2 11 P 1 1 638721.795144 220655.135048 2 12 P 1 1 638656.193203 220404.828666 2 13 P 1 1 638268.15133 220299.739643 2 14 P 1 1 638602.453907 220281.587467 2 15 P 1 1 638602.453907 220281.587467 8 1 P 1 1 638602.453907 220281.587467 8 2 P 1 1 638602.453907 220281.587467 4 1 P 1 1 638634.426432 220500.061126 4 2 P 1 1 638621.330858 220519.982685 4 3 P 1 1 638465.368943 220506.786855 4 4 P 1 1 638666.507984 220451.258691 4 5 P 1 1 638662.328095 220442.177014 4 6 P 1 1 638573.410617 220382.409616 4 7 P 1 1 638602.453907 220281.587467 4 8 P 1 1 638602.453907 220281.587467 3 1 P 1 1 638794.637722 220294.628116 3 2 P 1 1 638791.485541 220543.187779 3 3 P 1 1 638641.56261 220464.886873 3 4 P 1 1 638621.266312 220399.660839 3 5 P 1 1 638406.371565 220315.000175 3 6 P 1 1 638602.453907 220281.587467 3 7 P 1 1 638602.453907 220281.587467 7 1 P 1 1 638634.610948 220499.596419 7 2 P 1 1 638465.368943 220506.786855 7 3 P 1 1 638666.507984 220451.258691 7 4 P 1 1 638654.577521 220429.350321 7 5 P 1 1 638637.711356 220410.985026 7 6 P 1 1 638616.836773 220397.342402 7 7 P 1 1 638593.594427 220388.201219 7 8 P 1 1 638573.410617 220382.409616 7 9 P 1 1 638602.453907 220281.587467 7 10 P 1 1 638602.453907 220281.587467 5 1 P 1 1 638693.765832 220585.688009 5 2 P 1 1 638691.041172 220537.792247 5 3 P 1 1 638535.766657 220372.214897 5 4 P 1 1 638602.453907 220281.587467 5 5 P 1 1 638602.453907 220281.587467 6 1 P 1 1 638602.453907 220281.587467 6 2 " | v.in.ascii -n input=- output=Circuit format=standard --o
v.db.addtable map=Circuit table=Circuit_Plan layer=2 key=cat2 columns="pk_eje double precision,radio double precision,a_in double precision,a_out double precision,widening double precision,superelev varchar(25),dc_ double precision,lr_ double precision" v.db.addtable map=Circuit table=Circuit_Displ layer=8 key=cat8 columns="pk double precision,sec_left varchar(25),sec_right varchar(25),type_left varchar(25),type_right varchar(25)" v.db.addtable map=Circuit table=Circuit_Displ layer=4 key=cat4 columns="pk double precision,sec_left varchar(25),sec_right varchar(25),type_left varchar(25),type_right varchar(25)" v.db.addtable map=Circuit table=Circuit_Vert layer=3 key=cat3 columns="pk double precision,elev double precision,kv double precision,l double precision,b double precision" v.db.addtable map=Circuit table=Circuit_Marks layer=7 key=cat7 columns="pk double precision,dist varchar(25),elev varchar(25),azi varchar(25),name varchar(25),cod varchar(25)" v.db.addtable map=Circuit table=Circuit_Terr layer=5 key=cat5 columns="pk double precision,cut_left double precision,cut_right double precision,fill_left double precision,fill_right double precision,height double precision,leng double precision" v.db.addtable map=Circuit table=Circuit_Trans layer=6 key=cat6 columns="pk double precision,dist_left double precision,dist_right double precision,npk double precision" v.db.addtable map=Circuit table=Circuit layer=1 key=cat columns="name varchar(25)"
echo "UPDATE Circuit_Plan SET pk_eje='0.0',radio='0.0',a_in='0.0',a_out='0.0',widening='0.0',superelev='',dc_='0.0',lr_='140.002162531' WHERE cat2=1; UPDATE Circuit_Plan SET pk_eje='270.382786955',radio='-40.0',a_in='35.0',a_out='35.0',widening='0.0',superelev='',dc_='67.689561716',lr_='18.521314174' WHERE cat2=2; UPDATE Circuit_Plan SET pk_eje='461.124617255',radio='40.0',a_in='30.0',a_out='30.0',widening='0.0',superelev='',dc_='29.2637172691',lr_='39.7863972502' WHERE cat2=3; UPDATE Circuit_Plan SET pk_eje='573.256721368',radio='30.0',a_in='25.0',a_out='25.0',widening='0.0',superelev='',dc_='14.0798000021',lr_='1.81890329525' WHERE cat2=4; UPDATE Circuit_Plan SET pk_eje='682.835501948',radio='-15.0',a_in='15.0',a_out='15.0',widening='0.0',superelev='',dc_='25.5209406839',lr_='47.3026773599' WHERE cat2=5; UPDATE Circuit_Plan SET pk_eje='842.142623261',radio='-20.0',a_in='20.0',a_out='20.0',widening='0.0',superelev='',dc_='14.9175006172',lr_='100.00718402' WHERE cat2=6; UPDATE Circuit_Plan SET pk_eje='1123.60593223',radio='30.0',a_in='25.0',a_out='25.0',widening='0.0',superelev='',dc_='60.1666666667',lr_='24.9072874929' WHERE cat2=7; UPDATE Circuit_Plan SET pk_eje='1362.97515278',radio='-60.0',a_in='45.0',a_out='45.0',widening='0.0',superelev='',dc_='49.9304491395',lr_='25.1574394299' WHERE cat2=8; UPDATE Circuit_Plan SET pk_eje='1512.8365209',radio='-60.0',a_in='45.0',a_out='45.0',widening='0.0',superelev='',dc_='36.2500000006',lr_='68.9069121541' WHERE cat2=9; UPDATE Circuit_Plan SET pk_eje='1686.45923111',radio='-20.0',a_in='20.0',a_out='20.0',widening='0.0',superelev='',dc_='22.711648047',lr_='24.7225033281' WHERE cat2=10; UPDATE Circuit_Plan SET pk_eje='1782.75242935',radio='-40.0',a_in='25.0',a_out='25.0',widening='0.0',superelev='',dc_='14.6414158745',lr_='213.435753539' WHERE cat2=11; UPDATE Circuit_Plan SET pk_eje='2120.68119964',radio='20.0',a_in='20.0',a_out='20.0',widening='0.0',superelev='',dc_='33.810837057',lr_='71.3354524078' WHERE cat2=12; UPDATE Circuit_Plan SET pk_eje='2379.441513',radio='100.0',a_in='75.0',a_out='75.0',widening='0.0',superelev='',dc_='48.75',lr_='140.918379815' WHERE cat2=13; UPDATE Circuit_Plan SET pk_eje='2781.46165959',radio='-25.0',a_in='25.0',a_out='25.0',widening='0.0',superelev='',dc_='45.5718116349',lr_='160.427746506' WHERE cat2=14; UPDATE Circuit_Plan SET pk_eje='3116.25669305',radio='0.0',a_in='0.0',a_out='0.0',widening='0.0',superelev='',dc_='0.0',lr_='0.0' WHERE cat2=15; UPDATE Circuit_Displ SET pk='0.0',sec_left='6 0;3.5 0',sec_right='3.5 0;6 0',type_left='',type_right='' WHERE cat8=1; UPDATE Circuit_Displ SET pk='2208.88779535',sec_left='6 0;3.5 0',sec_right='3.5 0;6 0',type_left='',type_right='' WHERE cat8=2; UPDATE Circuit_Displ SET pk='0.0',sec_left='10 -0.34;8 -0.19;6.5 -0.13;4 -0.08',sec_right='4 -0.08;6.5 -0.13;8 -0.19;10 -0.34',type_left='l;l;e;e',type_right='e;e;l;l' WHERE cat4=1; UPDATE Circuit_Displ SET pk='876.0',sec_left='10 -0.34;-1 0;-1 0;-1 0',sec_right='-1 0;-1 0;-1 0;10 -0.34',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=2; UPDATE Circuit_Displ SET pk='900.0',sec_left='0 0;-1 0;-1 0;-1 0',sec_right='-1 0;-1 0;-1 0;0 0',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=3; UPDATE Circuit_Displ SET pk='1074.0',sec_left='10 -0.34;-1 0;-1 0;-1 0',sec_right='-1 0;-1 0;-1 0;10 -0.34',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=4; UPDATE Circuit_Displ SET pk='1690.0',sec_left='10 -0.34;-1 0;-1 0;-1 0',sec_right='-1 0;-1 0;-1 0;10 -0.34',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=5; UPDATE Circuit_Displ SET pk='1700.0',sec_left='0 0;-1 0;-1 0;-1 0',sec_right='-1 0;-1 0;-1 0;0 0',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=6; UPDATE Circuit_Displ SET pk='1811.0',sec_left='10 -0.34;-1 0;-1 0;-1 0',sec_right='-1 0;-1 0;-1 0;10 -0.34',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=7; UPDATE Circuit_Displ SET pk='2208.88779535',sec_left=' 10 -0.34;8 -0.19;6.5 -0.13;4 -0.08',sec_right='4 -0.08;6.5 -0.13;8 -0.19; 10 -0.34',type_left='l;l;l;l',type_right='l;l;l;l' WHERE cat4=8; UPDATE Circuit_Vert SET pk='0.0',elev='118.0',kv='0.0',l='0.0',b='0.0' WHERE cat3=1; UPDATE Circuit_Vert SET pk='200.0',elev='116.0',kv='-2500.0',l='0.0',b='0.0' WHERE cat3=2; UPDATE Circuit_Vert SET pk='550.0',elev='133.0',kv='3000.0',l='0.0',b='0.0' WHERE cat3=3; UPDATE Circuit_Vert SET pk='840.0',elev='114.0',kv='-2000.0',l='0.0',b='0.0' WHERE cat3=4; UPDATE Circuit_Vert SET pk='1760.0',elev='133.0',kv='3000.0',l='0.0',b='0.0' WHERE cat3=5; UPDATE Circuit_Vert SET pk='2000.0',elev='121.0',kv='-2000.0',l='0.0',b='0.0' WHERE cat3=6; UPDATE Circuit_Vert SET pk='2208.88779535',elev='118.0',kv='0.0',l='0.0',b='0.0' WHERE cat3=7; UPDATE Circuit_Marks SET pk='0.0',dist='',elev='',azi='',name='',cod='' WHERE cat7=1; UPDATE Circuit_Marks SET pk='875.5',dist='0',elev='0',azi='1',name='Bridge1',cod='a1' WHERE cat7=2; UPDATE Circuit_Marks SET pk='1074.0',dist='0',elev='0',azi='-1',name='Bridge2',cod='a1' WHERE cat7=3; UPDATE Circuit_Marks SET pk='1690.0',dist='0',elev='0',azi='1',name='Tunel1',cod='a2' WHERE cat7=4; UPDATE Circuit_Marks SET pk='1715.0',dist='0',elev='0',azi='1',name='Pila',cod='' WHERE cat7=5; UPDATE Circuit_Marks SET pk='1740.0',dist='0',elev='0',azi='1',name='Pila',cod='' WHERE cat7=6; UPDATE Circuit_Marks SET pk='1765.0',dist='0',elev='0',azi='1',name='Pila',cod='' WHERE cat7=7; UPDATE Circuit_Marks SET pk='1790.0',dist='0',elev='0',azi='1',name='Pila',cod='' WHERE cat7=8; UPDATE Circuit_Marks SET pk='1811.0',dist='0',elev='0',azi='-1',name='Tunel2',cod='a2' WHERE cat7=9; UPDATE Circuit_Marks SET pk='2208.88779535',dist='',elev='',azi='',name='',cod='' WHERE cat7=10; UPDATE Circuit_Terr SET pk='0.0',cut_left='2.0',cut_right='2.0',fill_left='0.5',fill_right='0.5',height='0.0',leng='0.0' WHERE cat5=1; UPDATE Circuit_Terr SET pk='1550.0',cut_left='2.0',cut_right='2.0',fill_left='0.5',fill_right='0.5',height='0.0',leng='0.0' WHERE cat5=2; UPDATE Circuit_Terr SET pk='1600.0',cut_left='2.0',cut_right='2.0',fill_left='4.0',fill_right='4.0',height='0.0',leng='0.0' WHERE cat5=3; UPDATE Circuit_Terr SET pk='1850.0',cut_left='2.0',cut_right='2.0',fill_left='0.5',fill_right='0.5',height='0.0',leng='0.0' WHERE cat5=4; UPDATE Circuit_Terr SET pk='2208.88779535',cut_left='2.0',cut_right='2.0',fill_left='0.5',fill_right='0.5',height='0.0',leng='0.0' WHERE cat5=5; UPDATE Circuit_Trans SET pk='0.0',dist_left='20.0',dist_right='20.0',npk='20.0' WHERE cat6=1; UPDATE Circuit_Trans SET pk='2208.88779535',dist_left='20.0',dist_right='20.0',npk='20.0' WHERE cat6=2; UPDATE Circuit SET name='Circuit' WHERE cat=1; " | db.execute input=- ```
SOURCE CODE
Available at: v.civil source code
(history)
Latest change: Wednesday Feb 18 06:57:16 2026 in commit b799fbf
