Skip to content
v.surf.rst.cv
Performs cross-validation proceedure to optimize the parameterization of v.surf.rst tension and smoothing paramters.
v.surf.rst.cv point_cloud=name [mask=name] [tension=integer [,integer,...]] [smooth=float [,float,...]] [layer=string] [zcolumn=name] [where=sql_query] [segmax=integer] [dmin=float] [dmax=float] [zscale=float] [theta=float] [scalex=float] [cv_prefix=string] [output_file=name] [format=name] [nprocs=integer] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
grass.tools.Tools.v_surf_rst_cv(point_cloud, mask=None, tension=10,20,40,60,80,100, smooth=0.01,0.1,0.5,1.0,5.0,10.0, layer="1", zcolumn=None, where=None, segmax=40, dmin=None, dmax=None, zscale=1.0, theta=None, scalex=None, cv_prefix=None, output_file=None, format="plain", nprocs=0, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.v_surf_rst_cv(point_cloud="name", format="json")
grass.script.parse_command("v.surf.rst.cv", point_cloud, mask=None, tension=10,20,40,60,80,100, smooth=0.01,0.1,0.5,1.0,5.0,10.0, layer="1", zcolumn=None, where=None, segmax=40, dmin=None, dmax=None, zscale=1.0, theta=None, scalex=None, cv_prefix=None, output_file=None, format="plain", nprocs=0, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.parse_command("v.surf.rst.cv", point_cloud="name", format="json")
Parameters
point_cloud=name [required]
    Name of the input point cloud vector map
mask=name
    Mask raster map
    Name of the mask raster map
    Tension parameter for cross-validation
    Default: 10,20,40,60,80,100
    Smoothing parameter for cross-validation
    Default: 0.01,0.1,0.5,1.0,5.0,10.0
layer=string
    Layer number or name
    Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name.
    Default: 1
zcolumn=name
    Name of the attribute column with values to be used for approximation
    If not given and input is 2D vector map then category values are used. If input is 3D vector map then z-coordinates are used.
where=sql_query
    WHERE conditions of SQL statement without 'where' keyword
    Example: elevation < 500 and elevation >= 1
segmax=integer
    Maximum number of points in segment
    Default: 40
dmin=float
    Minimum distance between points (to remove almost identical points). Default value is half of the smaller resolution of the current region.
dmax=float
    Maximum distance between points on isoline (to insert additional points)
zscale=float
    Conversion factor for values used for approximation
    Default: 1.0
theta=float
    Anisotropy angle (in degrees counterclockwise from East)
scalex=float
    Anisotropy scaling factor
cv_prefix=string
    Prefix to use for cross-validation output maps
    Prefix to use for cross-validation output cross-validation errors vector point map. Value must be set to save the cross-validation errors to a vector maps.
output_file=name
    Output file
    Output file for the results (default: None) json or csv
format=name
    Output format
    Allowed values: plain, json
    Default: plain
    plain: Plain text output
    json: JSON (JavaScript Object Notation)
nprocs=integer
    Default: 0
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
point_cloud : str, required
    Used as: input, vector, name
mask : str | np.ndarray, optional
    Mask raster map
    Used as: input, raster, name
tension : int | list[int] | str, optional
smooth : float | list[float] | str, optional
layer : str, optional
    Used as: input, layer
    Default: 1
zcolumn : str, optional
    Used as: input, dbcolumn, name
where : str, optional
    Used as: input, sql_query, sql_query
segmax : int, optional
    Default: 40
dmin : float, optional
dmax : float, optional
zscale : float, optional
    Default: 1.0
theta : float, optional
scalex : float, optional
cv_prefix : str, optional
output_file : str, optional
    Output file
    Used as: output, file, name
format : str, optional
    Output format
    Used as: name
    Default: plain
nprocs : int, optional
    Default: 0
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
Returns:
Raises:
mask : str, optional
    Mask raster map
    Default: 1
    Default: 40
    Default: 1.0
    Output file
    Output format
    Used as: name
    Default: plain
    Default: 0
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
DESCRIPTION
v.surf.rst.cv - Cross-validation of regularized spline with tension (RST) surface model.
Predictive error of surface approximation for given parameters are computed and a cross-validation procedure is then performed using the data given in the vector map input. The estimated predictive errors are stored in the optionally saved vector point map cvdev.
For larger data sets, CV should be applied to a representative subset of the data. The cross-validation procedure works well only for well-sampled phenomena and when minimizing the predictive error is the goal. The parameters found by minimizing the predictive (CV) error may not not be the best for for poorly sampled phenomena (result could be strongly smoothed with lost details and fluctuations) or when significant noise is present that needs to be smoothed out.
EXAMPLES
import grass.script as gs
gs.run_command(
    "g.region",
    raster="elevation",
    res=30,
    n=220790,
    s=218390,
    w=632680,
    e=635910,
    flags="a",
# Extract random elevation points from the DEM
gs.run_command(
    "r.random",
    input="elevation",
    npoints=500,
    seed=0,
    vector="points",
    flags="z",
    overwrite=True,
# Run the cross validation proceedure
# using the random points
gs.run_command('v.surf.rst.cv',
    point_cloud="points",
    tension=[10, 100],
    smooth=[0.5, 5.0],
    segmax=600,
    format="json",
    output_file="test_cv.json",
    cv_prefix='cvdev',
    overwrite=True
By setting the output_file and format options the output of the above command will be a JSON file with the cross-validation results. The file will contain the following information:
        "tension": "10",
        "smooth": "0.5",
        "rmse": 3.938792429360747,
        "mae": 3.2086477739999997
        "tension": "10",
        "smooth": "5.0",
        "rmse": 4.921535874096144,
        "mae": 4.075445157999998
        "tension": "100",
        "smooth": "0.5",
        "rmse": 2.715355217413409,
        "mae": 2.0061099599999994
        "tension": "100",
        "smooth": "5.0",
        "rmse": 3.438609351379808,
        "mae": 2.73388017
A report of the best parameter combination and the RMSE and MAE values will be printed to the stderr.
Best parameter combination
Tension: 100
Smoothing: 0.5
RMSE: 2.715355217413409
MAE: 2.0061099599999994
When the cv_prefix option is set, the vector point maps with the cross-validation results will be saved and interpolated into a new surface that displays the residuals of the cross-validation. The surface will be saved in the current mapset with the name <cv_prefix>_<tension>_<smooth>.
cdev-surface
Tension: 100 Smooth: 0.5 cdev-surface
Tension: 100 Smooth: 5 cdev-surface
Tension: 10 Smooth: 0.5 cdev-surface
Tension: 10 Smooth: 5
REFERENCES
  • Mitasova, H., Mitas, L. and Harmon, R.S., 2005, Simultaneous spline approximation and topographic analysis for lidar elevation data in open source GIS, IEEE GRSL 2 (4), 375- 379.
  • Hofierka, J., 2005, Interpolation of Radioactivity Data Using Regularized Spline with Tension. Applied GIS, Vol. 1, No. 2, pp. 16-01 to 16-13. DOI: 10.2104/ag050016
  • Hofierka J., Parajka J., Mitasova H., Mitas L., 2002, Multivariate Interpolation of Precipitation Using Regularized Spline with Tension. Transactions in GIS 6(2), pp. 135-150.
  • H. Mitasova, L. Mitas, B.M. Brown, D.P. Gerdes, I. Kosinovsky, 1995, Modeling spatially and temporally distributed phenomena: New methods and tools for GRASS GIS. International Journal of GIS, 9 (4), special issue on Integrating GIS and Environmental modeling, 433-446.
  • Mitasova, H. and Mitas, L., 1993: Interpolation by Regularized Spline with Tension: I. Theory and Implementation, Mathematical Geology ,25, 641-655.
  • Mitasova, H. and Hofierka, J., 1993: Interpolation by Regularized Spline with Tension: II. Application to Terrain Modeling and Surface Geometry Analysis, Mathematical Geology 25, 657-667.
  • Mitas, L., and Mitasova H., 1988, General variational approach to the approximation problem, Computers and Mathematics with Applications, v.16, p. 983-992.
  • Neteler, M. and Mitasova, H., 2008, Open Source GIS: A GRASS GIS Approach, 3rd Edition, Springer, New York, 406 pages.
  • Talmi, A. and Gilat, G., 1977 : Method for Smooth Approximation of Data, Journal of Computational Physics, 23, p.93-123.
  • Wahba, G., 1990, : Spline Models for Observational Data, CNMS-NSF Regional Conference series in applied mathematics, 59, SIAM, Philadelphia, Pennsylvania.
SEE ALSO
v.surf.rst
AUTHORS
Corey T. White NCSU GeoForAll Lab
