r.futures.validation
Module for land change simulation validation and accuracy assessment
r.futures.validation simulated=name reference=name [original=name] [format=string] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh
grass.script.parse_command("r.futures.validation", simulated, reference, original=None, format="plain", verbose=None, quiet=None, superquiet=None)
Example:
python
gs.parse_command("r.futures.validation", simulated="name", reference="name", format="json")
grass.tools.Tools.r_futures_validation(simulated, reference, original=None, format="plain", verbose=None, quiet=None, superquiet=None)
Example:
python
tools = Tools()
tools.r_futures_validation(simulated="name", reference="name", format="json")
Parameters
simulated=name [required]
Simulated land use raster
reference=name [required]
Reference land use raster
original=name
Original land use raster
Required for kappa simulation
format=string
Output format
Allowed values: plain, shell, json
Default: plain
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
simulated : str, required
Used as: input, raster, name
reference : str, required
original : str, optional
format : str, optional
Output format
Default: plain
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
simulated : str | np.ndarray, required
reference : str | np.ndarray, required
original : str | np.ndarray, optional
Output format
Default: plain
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
Module r.futures.validation allows to validate land change simulation results. It computes:
- Allocation disagreement (total and per class), see Pontius et al, 2011
- Quantity disagreement (total and per class), see Pontius et al, 2011
- Cohen's Kappa
- Kappa simulation, see van Vliet et al, 2011
This module can be used for any number of classes. Input raster original represents the initial conditions and is needed only for Kappa simulation.
EXAMPLES
Validate land change simulation output by computing quantity and allocation disagreement.
sh
r.reclass input=simulated_2016 output=simulated_2016_reclass rules=rules.txt
r.futures.validation simulated=simulated_2016_reclass reference=reference_2016 original=orig_2001
SEE ALSO
For alternative validation metrics see r.confusionmatrix, r.kappa
REFERENCES
- Robert Gilmore Pontius Jr & Marco Millones (2011). Death to Kappa: birth of quantity disagreement and allocation disagreement for accuracy assessment. International Journal of Remote Sensing, 32:15, 4407-4429
- Jasper van Vliet, Arnold K. Bregt, Alex Hagen-Zanker (2011) Revisiting Kappa to account for change in the accuracy assessment of land-use change models. Ecological Modelling, Volume 222, Issue 8.
- Meentemeyer, R. K., Tang, W., Dorning, M. A., Vogler, J. B., Cunniffe, N. J., & Shoemaker, D. A. (2013). FUTURES: Multilevel Simulations of Emerging Urban-Rural Landscape Structure Using a Stochastic Patch-Growing Algorithm. Annals of the Association of American Geographers, 103(4), 785-807. DOI: 10.1080/00045608.2012.707591
- Dorning, M. A., Koch, J., Shoemaker, D. A., & Meentemeyer, R. K. (2015). Simulating urbanization scenarios reveals tradeoffs between conservation planning strategies. Landscape and Urban Planning, 136, 28-39. DOI: 10.1016/j.landurbplan.2014.11.011
- Petrasova, A., Petras, V., Van Berkel, D., Harmon, B. A., Mitasova, H., & Meentemeyer, R. K. (2016). Open Source Approach to Urban Growth Simulation. Int. Arch. Photogramm. Remote Sens. Spatial Inf. Sci., XLI-B7, 953-959. DOI: 10.5194/isprsarchives-XLI-B7-953-2016
AUTHOR
Anna Petrasova, NCSU GeoForAll
SOURCE CODE
Available at: r.futures.validation source code
(history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
