Skip to content
r.green.biomassfor.theoretical
Estimates potential bioenergy depending on forest increment, forest management and forest treatment
r.green.biomassfor.theoretical forest=name boundaries=name [energy_tops_hf=float] [forest_column_increment=string] [forest_column_yield_surface=string] [forest_column_management=string] [forest_column_treatment=string] [output_basename=name] [energy_cormometric_vol_hf=float] [energy_tops_cop=float] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh r.green.biomassfor.theoretical forest=name boundaries=name
grass.script.run_command("r.green.biomassfor.theoretical", forest, boundaries, energy_tops_hf=0.49, forest_column_increment="increment", forest_column_yield_surface="yield_surface", forest_column_management="management", forest_column_treatment="treatment", output_basename="biomassfor", energy_cormometric_vol_hf=1.97, energy_tops_cop=0.55, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python gs.run_command("r.green.biomassfor.theoretical", forest="name", boundaries="name")
grass.tools.Tools.r_green_biomassfor_theoretical(forest, boundaries, energy_tops_hf=0.49, forest_column_increment="increment", forest_column_yield_surface="yield_surface", forest_column_management="management", forest_column_treatment="treatment", output_basename="biomassfor", energy_cormometric_vol_hf=1.97, energy_tops_cop=0.55, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python tools = Tools() tools.r_green_biomassfor_theoretical(forest="name", boundaries="name")
Parameters
forest=name [required]
    Name of vector parcel map
boundaries=name [required]
    Name of vector boundaries map (boolean map)
    Energy for tops and branches in high forest in MWh/m3
    Default: 0.49
    Vector field of increment
    Default: increment
    Vector field of stand surface (ha)
    Default: yield_surface
    Vector field of forest management (1: high forest, 2:coppice)
    Default: management
    Vector field of forest treatment (1: final felling, 2:thinning)
    Default: treatment
    Basename for potential bioenergy (HF,CC and total)
    Default: biomassfor
    Energy for the whole tree in high forest (tops, branches and stem) in MWh/m3
    Default: 1.97
    Energy for tops and branches for Coppices in MWh/m3
    Default: 0.55
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
forest : str, required
    Used as: input, vector, name
boundaries : str, required
energy_tops_hf : float, optional
    Default: 0.49
forest_column_increment : str, optional
    Default: increment
forest_column_yield_surface : str, optional
forest_column_management : str, optional
    Default: management
forest_column_treatment : str, optional
    Default: treatment
output_basename : str, optional
    Used as: output, , name
    Default: biomassfor
energy_cormometric_vol_hf : float, optional
    Default: 1.97
energy_tops_cop : float, optional
    Default: 0.55
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
    Default: 0.49
    Default: increment
    Default: management
    Default: treatment
    Default: biomassfor
    Default: 1.97
    Default: 0.55
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
Compute the theoretical biomass forestry residual potential, based on the annual/periodic forest increment.
NOTES
This module permits to evalute the maximum bio-energy from forest residual available in a particular area, on the base of the annual/periodic forest increment. The mandatory data input are a vector file with fields with values of increment, management, treatment, and forest surface. The increment value is expressed in cubic meters, the forest surface in hectares, the management is an integer value that can be 1 for high forest and 2 for coppice, the treatment is an integer field that can be 1 for final felling and 2 for thinning. The energy section contains the calorific parameters that permits to convert the biomass in energy. The output maps are expressed in Mwh.
EXAMPLE
This example shows a typical input vector file with a table composed by fields of increment, forest surface, management and treatment. This example is based on data of Maè Valley, one of the test area of the R.green project
image-alt
increment surface management treatment
35.87 1500 1 1
16.48 900 1 2
24.82 500 2 1
sh r.green.biomassfor.theoretical --overwrite forest=forest@biomasfor boundaries=Boundary@biomasfor forest_column_increment=increment forest_column_yield_surface=surface forest_column_management=management forest_column_treatment=treatment energy_tops_hs=0.49 energy_cormometric_vol_hf=1.97 energy_tops_cops=0.55 output_basename=mae
image-alt
The output map is a standardize energy map with the pixel value equal to the corresponding bioenergy stimated.
REFERENCE
Sacchelli, S., Zambelli, P., Zatelli, P., Ciolli, M., 2013. Biomasfor - an open-source holistic model for the assessment of sustainable forest bioenergy. iFor. Biogeosci. For. 6, 285-293
SEE ALSO
r.green.biomassfor.legal, r.green.biomassfor.technical
AUTHORS
Francesco Geri, Pietro Zambelli, Sandro Sacchelli, Marco Ciolli
SOURCE CODE
Available at: r.green.biomassfor.theoretical source code (history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
