r.slopeunits.metrics
Create metrics for slope units
r.slopeunits.metrics basin=name demmap=name slumapclean=name cleansize=float areamin=float cvmin=float resolution=float [outfile=name] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
r.slopeunits.metrics basin=name demmap=name slumapclean=name cleansize=25000 areamin=0.0 cvmin=0.0 resolution=0.0
grass.script.run_command("r.slopeunits.metrics", basin, demmap, slumapclean, cleansize=25000, areamin, cvmin, resolution, outfile=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("r.slopeunits.metrics", basin="name", demmap="name", slumapclean="name", cleansize=25000, areamin=0.0, cvmin=0.0, resolution=0.0)
grass.tools.Tools.r_slopeunits_metrics(basin, demmap, slumapclean, cleansize=25000, areamin, cvmin, resolution, outfile=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.r_slopeunits_metrics(basin="name", demmap="name", slumapclean="name", cleansize=25000, areamin=0.0, cvmin=0.0, resolution=0.0)
Parameters
basin=name [required]
    Name of input vector map
    Input basin
demmap=name [required]
    Input digital elevation model
slumapclean=name [required]
    Output Slope Units layer, cleaned (the main output)
cleansize=float [required]
    Slope Units size to be removed
    Default: 25000
areamin=float [required]
    Minimum area (m^2) below which the slope unit is not further segmented
cvmin=float [required]
    Minimum value of the circular variance (0.0-1.0) below which the slope unit is not further segmented
resolution=float [required]
    Resolution
outfile=name
    Output file with metrics
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
basin : str, required
    Input basin
    Used as: input, vector, name
demmap : str, required
    Used as: input, raster, name
slumapclean : str, required
    Used as: output, raster, name
cleansize : float, required
    Default: 25000
areamin : float, required
cvmin : float, required
resolution : float, required
    Resolution
outfile : str, optional
    Used as: output, file, name
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
    Input basin
demmap : str | np.ndarray, required
slumapclean : str | type(np.ndarray) | type(np.array) | type(gs.array.array), required
    Default: 25000
    Resolution
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
r.slopeunits.metrics creates metrics for slope units. Returns output "areamin, cvmin, v_fin and i_fin" to stdout, optionally writes to a file.
EXAMPLE
r.slopeunits.metrics \
    basin=basin_chk \
    demmap=dem_italia_isolegrandi@su_test \
    slumapclean=su_tmp_cl \
    cleansize=25000 \
    areamin=50000.0 \
    cvmin=0.05 \
    resolution=625 \
    outfile=objf_1.dat
REFERENCES
- Alvioli, M., Marchesini, I., Reichenbach, P., Rossi, M., Ardizzone, F., Fiorucci, F., and Guzzetti, F. (2016): Automatic delineation of geomorphological slope units with r.slopeunits v1.0 and their optimization for landslide susceptibility modeling, Geosci. Model Dev., 9, 3975-3991. DOI:10.5194/gmd-9-3975-2016
 - Alvioli, M., Guzzetti, F., & Marchesini, I. (2020): Parameter-free delineation of slope units and terrain subdivision of Italy. Geomorphology, 358, 107124. DOI:10.1016/j.geomorph.2020.107124
SEE ALSO
r.slopeunits.create, r.slopeunits.clean, r.slopeunits.optimize
AUTHORS
Main authors: Ivan Marchesini, Massimiliano Alvioli, CNR-IRPI
Carmen Tawalika (translation to python),
mundialis
SOURCE CODE
Available at: r.slopeunits.metrics source code
(history)
Latest change: Wednesday May 07 16:16:50 2025 in commit 8af96b6
