r.slopeunits.optimize
Optimize inputs for slope units
r.slopeunits.optimize [-s] demmap=name [plainsmap=name] basin=name slumap=name [slumapclean=name] thresh=float rf=integer maxiteration=integer cleansize=float cvmin=min,max areamin=min,max epsilonx=float epsilony=float outdir=name [convergence=integer] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh
r.slopeunits.optimize demmap=name basin=name slumap=su_tmp thresh=0.0 rf=0 maxiteration=0 cleansize=25000 cvmin=0.05,0.25 areamin=50000.0,200000.0 epsilonx=0.01 epsilony=50000 outdir=outdir
grass.script.run_command("r.slopeunits.optimize", demmap, plainsmap=None, basin, slumap="su_tmp", slumapclean="su_tmp_cl", thresh, rf, maxiteration, cleansize=25000, cvmin="0.05,0.25", areamin="50000.0,200000.0", epsilonx=0.01, epsilony=50000, outdir="outdir", convergence=5, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
gs.run_command("r.slopeunits.optimize", demmap="name", basin="name", slumap="su_tmp", thresh=0.0, rf=0, maxiteration=0, cleansize=25000, cvmin=0.05,0.25, areamin=50000.0,200000.0, epsilonx=0.01, epsilony=50000, outdir="outdir")
grass.tools.Tools.r_slopeunits_optimize(demmap, plainsmap=None, basin, slumap="su_tmp", slumapclean="su_tmp_cl", thresh, rf, maxiteration, cleansize=25000, cvmin="0.05,0.25", areamin="50000.0,200000.0", epsilonx=0.01, epsilony=50000, outdir="outdir", convergence=5, flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
tools = Tools()
tools.r_slopeunits_optimize(demmap="name", basin="name", slumap="su_tmp", thresh=0.0, rf=0, maxiteration=0, cleansize=25000, cvmin=0.05,0.25, areamin=50000.0,200000.0, epsilonx=0.01, epsilony=50000, outdir="outdir")
Parameters
demmap=name [required]
Input digital elevation model
plainsmap=name
Input raster map of alluvial plains
basin=name [required]
Name of input vector map
Input basin passed to r.slopeunits.metrics
slumap=name [required]
Slope Units layer (the main output of r.slopeunits.create)
Default: su_tmp
slumapclean=name
Slope Units layer, cleaned (the main output of r.slopeunits.clean)
Default: su_tmp_cl
thresh=float [required]
Initial threshold (m^2)
rf=integer [required]
Factor used to iterativelly reduce initial threshold
maxiteration=integer [required]
maximum number of iteration to do before stopped
cleansize=float [required]
Slope Units size to be removed
Default: 25000
cvmin=min,max [required]
Start search with these initial minimum and maximum values of the circular variance (0.0-1.0) below which the slope unit is not further segmented
Default: 0.05,0.25
areamin=min,max [required]
Start search with these initial minimum and maximum values of the area (m^2) below which the slope unit is not further segmented
Default: 50000.0,200000.0
epsilonx=float [required]
Stop loop when difference of cvmin limits is lesser than this value
Default: 0.01
epsilony=float [required]
Stop loop when difference of areamin limits is lesser than this value
Default: 50000
outdir=name [required]
Output directory for intermediate results for all cvmin and areamin values and final results. Default folder "outdir" in current working directory.
Default: outdir
convergence=integer
Convergence factor for MFD in r.watershed (1-10)
1 = most diverging flow, 10 = most converging flow. Recommended: 5
Default: 5
-s
SFD (D8) flow in r.watershed (default is MFD)
SFD: single flow direction, MFD: multiple flow direction
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
demmap : str, required
Used as: input, raster, name
plainsmap : str, optional
basin : str, required
Used as: input, vector, name
slumap : str, required
Used as: output, raster, name
Default: su_tmp
slumapclean : str, optional
Default: su_tmp_cl
thresh : float, required
rf : int, required
maxiteration : int, required
cleansize : float, required
Default: 25000
cvmin : tuple[float, float] | list[float] | str, required
Used as: min,max
Default: 0.05,0.25
areamin : tuple[float, float] | list[float] | str, required
Used as: min,max
epsilonx : float, required
Default: 0.01
epsilony : float, required
Default: 50000
outdir : str, required
Used as: input, dir, name
Default: outdir
convergence : int, optional
Default: 5
flags : str, optional
Allowed values: s
s
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
demmap : str | np.ndarray, required
plainsmap : str | np.ndarray, optional
slumap : str | type(np.ndarray) | type(np.array) | type(gs.array.array), required
Default: su_tmp
slumapclean : str | type(np.ndarray) | type(np.array) | type(gs.array.array), optional
Default: su_tmp_cl
rf : int, required
Default: 25000
Used as: min,max
Default: 0.05,0.25
Used as: min,max
Default: 0.01
Default: 50000
Default: outdir
Default: 5
Allowed values: s
s
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
r.slopeunits.optimize determines optimal input values for slope units:
- "areamin" - Minimum area (m^2) below which the slope unit is not further segmented
- "cvmin" - Minimum value of the circular variance (0.0-1.0) below which the slope unit is not further segmented
It calls r.slopeunits.create, r.slopeunits.clean, and
r.slopeunits.metrics iteratively. Output is a file opt.txt with
optimal values in either specified folder or in folder output/" in the
current working directory. Also files calcd.dat and current.txt are
created with all determined and examined values and the four latest
examined values (combination of
areamin`` and ``cvmin`` minimum and maximum) and ``center``, respectively.
EXAMPLE
sh
r.slopeunits.optimize \
basin=basin_chk \
demmap=dem_italia_isolegrandi@su_test \
plainsmap=flat \
thresh=250000 \
rf=2 \
maxiteration=50 \
cleansize=25000
REFERENCES
- Alvioli, M., Marchesini, I., Reichenbach, P., Rossi, M., Ardizzone, F., Fiorucci, F., and Guzzetti, F. (2016): Automatic delineation of geomorphological slope units with r.slopeunits v1.0 and their optimization for landslide susceptibility modeling, Geosci. Model Dev., 9, 3975-3991. DOI:10.5194/gmd-9-3975-2016
- Alvioli, M., Guzzetti, F., & Marchesini, I. (2020): Parameter-free delineation of slope units and terrain subdivision of Italy. Geomorphology, 358, 107124. DOI:10.1016/j.geomorph.2020.107124
SEE ALSO
r.slopeunits.create, r.slopeunits.clean, r.slopeunits.metrics
AUTHORS
Main authors: Ivan Marchesini, Massimiliano Alvioli, CNR-IRPI
Carmen Tawalika (translation to python, refactoring),
mundialis
SOURCE CODE
Available at: r.slopeunits.optimize source code
(history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
