v.what.strds.timestamp
Uploads space time raster dataset values to the attribute table at positions of vector points in space and time.
v.what.strds.timestamp [-i] input=name layer=string timestamp_column=name column=name [where=sql_query] strds=name [,name,...] [t_where=sql_query] [--verbose] [--quiet] [--qq] [--ui]
Example:
v.what.strds.timestamp input=name layer=1 timestamp_column=name column=name strds=name
grass.script.run_command("v.what.strds.timestamp", input, layer="1", timestamp_column, column, where=None, strds, t_where=None, flags=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("v.what.strds.timestamp", input="name", layer="1", timestamp_column="name", column="name", strds="name")
grass.tools.Tools.v_what_strds_timestamp(input, layer="1", timestamp_column, column, where=None, strds, t_where=None, flags=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.v_what_strds_timestamp(input="name", layer="1", timestamp_column="name", column="name", strds="name")
Parameters
input=name [required]
Name of input vector map
Or data source for direct OGR access
layer=string [required]
Layer number or name
Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name.
Default: 1
timestamp_column=name [required]
Column of input vector map containing time stamps for temoral sampling of STRDS
Name of attribute column
Column of input vector map to which raster values are written
Column will be added if it does not exists or updated otherwise
where=sql_query
Where-clause for filtering points in input vector map used for sampling
Example: income < 1000 and population >= 10000
strds=name [,name,...] [required]
Name of the input space time raster datasets
t_where=sql_query
WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework
Temporal where-clause for selecting a subset of raster maps from STRDS for sampling (Default: The temporal bounding box of the input vector points)
-i
Interpolate raster values from the four nearest pixels
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
input : str, required
Used as: input, vector, name
layer : str, required
Used as: input, layer
Default: 1
timestamp_column : str, required
Used as: input, dbcolumn, name
where : str, optional
Used as: input, sql_query, sql_query
strds : str | list[str], required
Used as: input, strds, name
t_where : str, optional
Used as: sql_query
flags : str, optional
Allowed values: i
i
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
Default: 1
Used as: sql_query
Allowed values: i
i
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
v.what.strds.timestamp matches points with a timestamp in the attribute table (timestamp_column) (e.g. recordings from stationary (temperature logger, wildlife camera traps) or non-stationary sensors (e.g GPS collars)) with Space Time Raster Datasets (STRDS) based on point locaitions in space and time. Raster values at the specific space-time position are written into the user-defined column in the attribute table of the input vector map.
NOTES
The SQLite DB backend does not provide specific date/datetime datatypes. However, text columns with ISO formated date strings are supported for the timestamp_column as well.
Curretnly, only STRDS with absolute temporal type are supported.
EXAMPLE
This example is based on the MODIS LST raster time series sample dataset (mapset "modis_lst") available for the North Carolina sample location which can be downloaded from the GRASS GIS website.
# Check time MODIS LST raster time series to sample
t.rast.list LST_Day_monthly@modis_lst
# Set computational region to first raster map of the time series
g.region -up raster=MOD11B3.A2015001.h11v05.single_LST_Day_6km \
align=MOD11B3.A2015001.h11v05.single_LST_Day_6km
# Create sampling points map with timestamp column for sampling time
echo "cat,sampling_time,x,y
1,2015-01-12,-125870.664090128,591821.149756026
2,2015-02-01,77667.7974483332,571718.585653462
3,2015-02-27,351565.233345769,481257.047191923
4,2015-03-10,565154.976935513,375718.585653462
5,2015-04-07,366642.156422692,277718.585653462
6,2015-05-22,178180.617961154,363154.483089359
7,2015-06-12,12334.464115,395821.149756026
8,2016-03-04,112847.28462782,204846.790781667
9,2016-05-12,311360.105140641,26436.5343714103
10,2017-01-03,467154.976935513,8846.79078166676
11,2018-01-01,600334.464115,129462.175397051
12,2016-06-07,690796.002576538,262641.662576539
13,2016-08-16,685770.361550897,441051.918986795
14,2016-12-11,625462.669243205,594333.970268846" > sampling_points.txt
# Import sampling points
v.in.ascii in=sampling_points.txt out=sampling_points x=3 y=4 cat=1 \
columns='cat int, sampling_time date, x double precision, y double precision' \
separator="," skip=1
# Assign LST values to sampling points at time of sampling
v.what.strds.timestamp input=sampling_points \
timestamp_column=sampling_time column=lst_at_sampling_time \
strds=LST_Day_monthly@modis_lst
# Check result
v.db.select sampling_points
cat|sampling_time|x|y|lst_at_sampling_time
1|2015-01-12|-125870.664090128|591821.149756026|13811
2|2015-02-01|77667.7974483332|571718.585653462|13486
3|2015-02-27|351565.233345769|481257.047191923|13793
4|2015-03-10|565154.976935513|375718.585653462|14355
5|2015-04-07|366642.156422692|277718.585653462|14565
6|2015-05-22|178180.617961154|363154.483089359|14864
7|2015-06-12|12334.464115|395821.149756026|15091
8|2016-03-04|112847.28462782|204846.790781667|14641
9|2016-05-12|311360.105140641|26436.5343714103|14982
10|2017-01-03|467154.976935513|8846.79078166676|
11|2018-01-01|600334.464115|129462.175397051|
12|2016-06-07|690796.002576538|262641.662576539|15052
13|2016-08-16|685770.361550897|441051.918986795|15052
14|2016-12-11|625462.669243205|594333.970268846|13920
# Check result for point with category 5
r.what -n map=MOD11B3.A2015091.h11v05.single_LST_Day_6km@modis_lst \
coordinates=366642.156422692,277718.585653462
# add extra column for LST in degree Celsius
v.db.addcolumn map=sampling_points column="lst_celsius double precision"
# rescale original MODIS LST to degree Celsius
v.db.update map=sampling_points column="lst_celsius" query_column="lst_at_sampling_time * 0.02 - 273.15"
SEE ALSO
v.what.rast, v.what.strds, r.connectivity.corridors
AUTHOR
Stefan Blumentrath, Norwegian Institute for Nature Research (NINA)
Written for the 2018 IRSAE GRASS GIS course at
Studenterhytta, Oslo
SOURCE CODE
Available at: v.what.strds.timestamp source code
(history)
Latest change: Thursday Feb 20 13:02:26 2025 in commit 53de819
