r.richdem.breachdepressions
Breaches depressions using RichDEM
r.richdem.breachdepressions input=name [topology=string] output=name [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
r.richdem.breachdepressions input=name output=name
grass.script.run_command("r.richdem.breachdepressions", input, topology="D8", output, overwrite=False, verbose=False, quiet=False, superquiet=False)
Example:
gs.run_command("r.richdem.breachdepressions", input="name", output="name")
Parameters
input=name [required]
Input DEM
Name of input raster map
topology=string
D4 or D8 flow routing?
Allowed values: D4, D8
Default: D8
output=name [required]
Output DEM with depressions breached
Name for output raster map
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
input : str, required
Input DEM
Used as: input, raster, name
topology : str, optional
Default: D8
output : str, required
Used as: output, raster, name
overwrite: bool, optional
Default: False
verbose: bool, optional
Default: False
quiet: bool, optional
Quiet module output
Default: False
superquiet: bool, optional
Default: False
DESCRIPTION
PLACEHOLDER
REFERENCES
PLACEHOLDER
SEE ALSO
AUTHORS
Richard Barnes (algorithm and codebase), Andrew D. Wickert (GRASS frontend)
SOURCE CODE
Available at: r.richdem.breachdepressions source code
(history)
Latest change: Thursday Feb 20 13:02:26 2025 in commit 53de819
