r.richdem.resolveflats
Directs flow from flat areas on depression-filled DEMs
r.richdem.resolveflats input=name output=name [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh
grass.script.run_command("r.richdem.resolveflats", input, output, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
gs.run_command("r.richdem.resolveflats", input="name", output="name")
grass.tools.Tools.r_richdem_resolveflats(input, output, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
tools = Tools()
tools.r_richdem_resolveflats(input="name", output="name")
Parameters
input=name [required]
Input DEM (most commonly with depressions filled)
Name of input raster map
output=name [required]
Output DEM with flats resolved for continuous flow
Name for output raster map
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
input : str, required
Used as: input, raster, name
output : str, required
Used as: output, raster, name
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
input : str | np.ndarray, required
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
PLACEHOLDER
REFERENCES
PLACEHOLDER
SEE ALSO
AUTHORS
Richard Barnes (algorithm and codebase), Andrew D. Wickert (GRASS frontend)
SOURCE CODE
Available at: r.richdem.resolveflats source code
(history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
