Skip to content
r.richdem.flowaccumulation
Calculates flow accumulation via one of a variety of methods.
r.richdem.flowaccumulation input=name [weights=name] method=string [exponent=float] output=name [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh r.richdem.flowaccumulation input=name method=Dinf output=name
grass.script.run_command("r.richdem.flowaccumulation", input, weights=None, method, exponent=None, output, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python gs.run_command("r.richdem.flowaccumulation", input="name", method="Dinf", output="name")
grass.tools.Tools.r_richdem_flowaccumulation(input, weights=None, method, exponent=None, output, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python tools = Tools() tools.r_richdem_flowaccumulation(input="name", method="Dinf", output="name")
Parameters
input=name [required]
    Input DEM
    Name of input raster map
weights=name
    Raster defining the amount of runoff per cell
method=string [required]
    Method to compute the flow routing.
    Allowed values: Dinf, Quinn, Holmgren, Freeman, Rho8, Rho4, D8, D4
exponent=float
    Exponent required for Holmgren and Freeman methods
output=name [required]
    Output DEM with depressions filled
    Name for output raster map
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
input : str, required
    Input DEM
    Used as: input, raster, name
weights : str, optional
method : str, required
exponent : float, optional
output : str, required
    Used as: output, raster, name
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
input : str | np.ndarray, required
    Input DEM
weights : str | np.ndarray, optional
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
PLACEHOLDER
REFERENCES
PLACEHOLDER
SEE ALSO
r.fill.dir
AUTHORS
Richard Barnes (algorithm and codebase), Andrew D. Wickert (GRASS frontend)
SOURCE CODE
Available at: r.richdem.flowaccumulation source code (history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
