Skip to content
r.richdem.filldepressions
Floods depressions using RichDEM
r.richdem.filldepressions input=name [epsilon=string] [topology=string] output=name [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
r.richdem.filldepressions input=name output=name
grass.script.run_command("r.richdem.filldepressions", input, epsilon="false", topology="D8", output, overwrite=False, verbose=False, quiet=False, superquiet=False)
Example:
gs.run_command("r.richdem.filldepressions", input="name", output="name")
Parameters
input=name [required]
    Input DEM
    Name of input raster map
epsilon=string
    If true, applies a small (epsilon) gradient to flats
    Allows downslope water routing across flats
    Allowed values: true, false
    Default: false
topology=string
    D4 or D8 flow routing?
    Chooses the topologic model
    Allowed values: D4, D8
    Default: D8
output=name [required]
    Output DEM with depressions filled
    Name for output raster map
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
input : str, required
    Input DEM
    Used as: input, raster, name
epsilon : str, optional
    Default: false
topology : str, optional
    Default: D8
output : str, required
    Used as: output, raster, name
overwrite: bool, optional
    Default: False
verbose: bool, optional
    Default: False
quiet: bool, optional
    Quiet module output
    Default: False
superquiet: bool, optional
    Default: False
DESCRIPTION
PLACEHOLDER
REFERENCES
PLACEHOLDER
SEE ALSO
r.fill.dir
AUTHORS
Richard Barnes (algorithm and codebase), Andrew D. Wickert (GRASS frontend)
SOURCE CODE
Available at: r.richdem.filldepressions source code (history)
Latest change: Thursday Feb 20 13:02:26 2025 in commit 53de819
