r.green.hydro.delplants
Delete segments where there is an existing plant
r.green.hydro.delplants [-d] hydro=name [hydro_layer=string] river=name output_streams=string [output_plants=string] [hydro_kind_intake=string] [hydro_kind_turbine=string] elevation=name [other=name] [other_layer=name] [other_kind_intake=string] [other_kind_turbine=string] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
r.green.hydro.delplants hydro=name river=name output_streams=string elevation=name
grass.script.run_command("r.green.hydro.delplants", hydro, hydro_layer="1", river, output_streams, output_plants=None, hydro_kind_intake="intake", hydro_kind_turbine="restitution", elevation, other=None, other_layer="1", other_kind_intake="intake", other_kind_turbine="restitution", flags=None, overwrite=False, verbose=False, quiet=False, superquiet=False)
Example:
gs.run_command("r.green.hydro.delplants", hydro="name", river="name", output_streams="string", elevation="name")
Parameters
hydro=name [required]
Name of the vector map with the points (intake and restitution) of hydropower plants
Or data source for direct OGR access
hydro_layer=string
Name of the vector map layer of the hydropower plants, with the following attributes: kind_label (intake/restitution), discharge [m3/s], id_point, id_plant
Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name.
Default: 1
river=name [required]
Name of the vector map with the streams
output_streams=string [required]
Name of the vector map with the stream segments without plants
Name of the vector map with the stream segments of the existing plants
Value contained in the column kind_label that indicates the plant is an intake
Default: intake
Value contained in the column kind_label that indicates the plant is a restitution
Default: restitution
elevation=name [required]
Name of input elevation raster map
other=name
Name of the vector map with points (intake and restitution) of other plants such as irrigation, acqueducts, etc.
other_layer=name
Name of the vector map layer of other plants, with the following attributes: kind_label (intake/restitution), discharge [m3/s], id_point, id_plant
Default: 1
Default: intake
-d
Debug with intermediate maps
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
hydro : str, required
Used as: input, vector, name
hydro_layer : str, optional
Used as: input, layer
Default: 1
river : str, required
output_streams : str, required
output_plants : str, optional
hydro_kind_intake : str, optional
Default: intake
hydro_kind_turbine : str, optional
elevation : str, required
Used as: input, raster, name
other : str, optional
other_layer : str, optional
Default: 1
other_kind_intake : str, optional
Default: intake
other_kind_turbine : str, optional
flags : str, optional
Allowed values: d
d
overwrite: bool, optional
Default: False
verbose: bool, optional
Default: False
quiet: bool, optional
Quiet module output
Default: False
superquiet: bool, optional
Default: False
DESCRIPTION
r.green.hydro.delplants deletes segments of river where there is an existing plant.
NOTES
This command is used to select the segments of river which are not
already exploited by a plant or another structure.
The required inputs are the elevation raster map, the map with the
streams and the one with the intakes and restitution of the existing
plants. In option, it is possible to add the map with the intakes and
restitution of the other structures such aqueducts or irrigation in
order to delete these segments too.
It is necessary to verify in "Optional" that the intakes and restitution
are well reported in the table of the input maps (hydro and other).
EXAMPLE
This example is based on the case-study of Mis valley in Belluno province, Veneto, Italy.
Input vector maps : streams of Mis Valley in black and intakes and
restitution of existing plants in red
We use the following code to compute the available streams and obtain the next map :
r.green.hydro.delplants hydro=existingplants river=streams output=availablestreams elevation=elevation
d.vect map=existingplants color=red
Output vector map in black : streams of Mis Valley without the existing
plants (intakes and restitution of existing plants are added there in
red)
SEE ALSO
r.green.hydro.discharge
r.green.hydro.financial
r.green.hydro.theoretical
r.green.hydro.optimal
r.green.hydro.recommended
r.green.hydro.structure
r.green.hydro.technical
AUTHORS
Giulia Garegnani and Pietro Zambelli (Eurac Research, Bolzano, Italy), Manual written by Julie Gros.
SOURCE CODE
Available at: r.green.hydro.delplants source code
(history)
Latest change: Friday Feb 21 10:10:05 2025 in commit 7d78fe3
