r.green.hydro.financial
Assess the financial costs and values
r.green.hydro.financial plant=name struct=name [plant_layer=string] [struct_layer=string] [struct_column_id=string] [struct_column_power=string] [struct_column_head=string] [struct_column_side=string] [struct_column_kind=string] [struct_kind_intake=string] [struct_kind_turbine=string] [plant_column_id=string] [plant_basename=string] [interest_rate=float] [gamma_comp=float] [life=float] [landvalue=name] [tributes=name] [stumpage=name] [rotation=name] [age=name] [landuse=name] [rules_landvalue=string] [rules_tributes=string] [rules_stumpage=string] [rules_rotation=string] [rules_age=string] [width=float] [depth=float] [slope_limit=float] [min_exc=name] [max_exc=name] slope=name [rules_min_exc=string] [rules_max_exc=string] [alpha_em=float] [beta_em=float] [gamma_em=float] [const_em=float] [lc_pipe=float] [lc_electro=float] electro=name [electro_layer=string] [elines=string] [alpha_station=float] [alpha_inlet=float] [grid=float] [general=float] [hindrances=float] [cost_maintenance_per_kw=float] [alpha_maintenance=float] [beta_maintenance=float] [const_maintenance=float] [energy_price=float] [eta=float] [operative_hours=float] [const_revenue=float] output_struct=name [compensation=name] [excavation=name] [upper=name] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
r.green.hydro.financial plant=name struct=name slope=name electro=name output_struct=name
grass.script.run_command("r.green.hydro.financial", plant, struct, plant_layer="1", struct_layer="1", struct_column_id="plant_id", struct_column_power="power", struct_column_head="gross_head", struct_column_side="side", struct_column_kind="kind", struct_kind_intake="conduct", struct_kind_turbine="penstock", plant_column_id="plant_id", plant_basename="case1", interest_rate=0.03, gamma_comp=1.25, life=30, landvalue=None, tributes=None, stumpage=None, rotation=None, age=None, landuse=None, rules_landvalue=None, rules_tributes=None, rules_stumpage=None, rules_rotation=None, rules_age=None, width=2., depth=2., slope_limit=50., min_exc=None, max_exc=None, slope, rules_min_exc=None, rules_max_exc=None, alpha_em=0.56, beta_em=-0.112, gamma_em=15600.0, const_em=0., lc_pipe=310., lc_electro=250., electro, electro_layer="1", elines=None, alpha_station=0.52, alpha_inlet=0.38, grid=50000, general=0.15, hindrances=0.1, cost_maintenance_per_kw=7000., alpha_maintenance=0.05, beta_maintenance=0.45, const_maintenance=0., energy_price=0.1, eta=0.81, operative_hours=3392., const_revenue=0., output_struct, compensation=None, excavation=None, upper=None, overwrite=False, verbose=False, quiet=False, superquiet=False)
Example:
gs.run_command("r.green.hydro.financial", plant="name", struct="name", slope="name", electro="name", output_struct="name")
Parameters
plant=name [required]
Name of the input vector map with the segments of the plants
Or data source for direct OGR access
struct=name [required]
Name of the input vector map with the structure of the plants
plant_layer=string
Name of the vector map layer of the segments
Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name.
Default: 1
struct_layer=string
Name of the vector map layer of the structure of the plants
Default: 1
Table of the struct map: column name with plant id
Default: plant_id
Table of the struct map: column name with power value
Default: power
Table of the struct map: column name with head value
Default: gross_head
Table of the struct map: column name with the strings that define the side of the plant
Default: side
Table of the struct map: column name with the strings that define if it's a derivation channel or a penstock
Default: kind
Table of the structures map: Value contained in the column 'kind' which corresponds to the derivation channel
Default: conduct
Table of the structures map: Value contained in the column 'kind' which corresponds to the penstock
Default: penstock
Table of the plants map: Column name with the plant id
Default: plant_id
Table of the plants map: basename of the columns that will be added to the input plants vector map
Default: case1
interest_rate=float
Interest rate value
Default: 0.03
gamma_comp=float
Coefficient
Default: 1.25
life=float
Life of the hydropower plant [year]
Default: 30
landvalue=name
Name of the raster map with the land value [currency/ha]
Name of input raster map
tributes=name
Name of the raster map with the tributes [currency/ha]
stumpage=name
Name of the raster map with the stumpage value [currency/ha]
rotation=name
Name of the raster map with the rotation period per landuse type [year]
age=name
Name of the raster map with the average age [year]
landuse=name
Name of the raster map with the landuse categories
Rule file for the reclassification of the landuse to associate a value for each landuse [currency/ha]
Rule file for the reclassification of the landuse to associate a tribute rate for each landuse [currency/ha]
Rule file for the reclassification of the landuse to associate a stumpage value for each landuse [currency/ha]
Rule file for the reclassification of the landuse to associate a rotation value for each landuse [year]
rules_age=string
Rule file for the reclassification of the landuse to associate an age for each landuse [year]
width=float
Width of the excavation works [m]
Default: 2.
depth=float
Depth of the excavation works [m]
Default: 2.
slope_limit=float
Slope limit, above this limit the cost will be equal to the maximum [degree]
Default: 50.
min_exc=name
Minimum excavation costs [currency/mc]
max_exc=name
Maximum excavation costs [currency/mc]
slope=name [required]
Slope raster map
Rule file for the reclassification of the landuse to associate a minimum excavation cost for each landuse [currency/mc].
Rule file for the reclassification of the landuse to associate a maximum excavation cost for each landuse [currency/mc].
alpha_em=float
Electro-mechanical costs alpha parameter, default values taken from Aggidis et al. 2010
Default: 0.56
beta_em=float
Electro-mechanical costs beta parameter, default values taken from Aggidis et al. 2010
Default: -0.112
gamma_em=float
Electro-mechanical costs gamma parameter, default values taken from Aggidis et al. 2010
Default: 15600.0
const_em=float
Electro-mechanical costs constant value, default values taken from Aggidis et al. 2010
Default: 0.
lc_pipe=float
Supply and installation linear cost for the pipeline [currency/m]
Default: 310.
lc_electro=float
Supply and installation linear cost for the electroline [currency/m]
Default: 250.
electro=name [required]
Name of the vector map with the electric grid
Vector map layer of the grid
Default: 1
elines=string
Output name of the vector map with power lines
alpha_station=float
Power station costs are assessed as a fraction of the Electro-mechanical costs
Default: 0.52
alpha_inlet=float
Inlet costs are assessed as a fraction of the Electro-mechanical costs
Default: 0.38
grid=float
Cost for grid connection
Default: 50000
general=float
Factor for general expenses
Default: 0.15
hindrances=float
Factor for hindrances expenses
Default: 0.1
Maintenace costs per kW
Default: 7000.
Alpha coefficient to assess the maintenance costs
Default: 0.05
Beta coefficient to assess the maintenance costs
Default: 0.45
Constant to assess the maintenance costs
Default: 0.
energy_price=float
Energy price per kW [currency/kW]
Default: 0.1
eta=float
Efficiency of electro-mechanical components
Default: 0.81
Number of operative hours per year [hours/year]
Default: 3392.
const_revenue=float
Constant to assess the revenues
Default: 0.
output_struct=name [required]
Name of the output vector map: plants' structure including the main costs in the table
Name for output vector map
compensation=name
Output raster map with the compensation values
Name for output raster map
excavation=name
Output raster map with the excavation costs
upper=name
Output raster map with the value upper part of the soil
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
plant : str, required
Used as: input, vector, name
struct : str, required
plant_layer : str, optional
Used as: input, layer
Default: 1
struct_layer : str, optional
Default: 1
struct_column_id : str, optional
Default: plant_id
struct_column_power : str, optional
Default: power
struct_column_head : str, optional
Default: gross_head
struct_column_side : str, optional
Default: side
struct_column_kind : str, optional
Default: kind
struct_kind_intake : str, optional
Default: conduct
struct_kind_turbine : str, optional
Default: penstock
plant_column_id : str, optional
Default: plant_id
plant_basename : str, optional
Default: case1
interest_rate : float, optional
Interest rate value
Default: 0.03
gamma_comp : float, optional
Coefficient
Default: 1.25
life : float, optional
Default: 30
landvalue : str, optional
Used as: input, raster, name
tributes : str, optional
stumpage : str, optional
rotation : str, optional
age : str, optional
landuse : str, optional
rules_landvalue : str, optional
rules_tributes : str, optional
rules_stumpage : str, optional
rules_rotation : str, optional
rules_age : str, optional
width : float, optional
Default: 2.
depth : float, optional
Default: 2.
slope_limit : float, optional
Default: 50.
min_exc : str, optional
max_exc : str, optional
slope : str, required
Slope raster map
rules_min_exc : str, optional
rules_max_exc : str, optional
alpha_em : float, optional
Default: 0.56
beta_em : float, optional
Default: -0.112
gamma_em : float, optional
Default: 15600.0
const_em : float, optional
Default: 0.
lc_pipe : float, optional
Default: 310.
lc_electro : float, optional
Default: 250.
electro : str, required
electro_layer : str, optional
Default: 1
elines : str, optional
alpha_station : float, optional
Default: 0.52
alpha_inlet : float, optional
Default: 0.38
grid : float, optional
Default: 50000
general : float, optional
Default: 0.15
hindrances : float, optional
Default: 0.1
cost_maintenance_per_kw : float, optional
Default: 7000.
alpha_maintenance : float, optional
Default: 0.05
beta_maintenance : float, optional
Default: 0.45
const_maintenance : float, optional
Default: 0.
energy_price : float, optional
Default: 0.1
eta : float, optional
Default: 0.81
operative_hours : float, optional
Default: 3392.
const_revenue : float, optional
Default: 0.
output_struct : str, required
Used as: output, vector, name
compensation : str, optional
Used as: output, raster, name
excavation : str, optional
upper : str, optional
overwrite: bool, optional
Default: False
verbose: bool, optional
Default: False
quiet: bool, optional
Quiet module output
Default: False
superquiet: bool, optional
Default: False
DESCRIPTION
r.green.hydro.financial computes the economic costs and values of the plants. It provides an analysis calculating realization costs and profits for each potential plant in order to know which ones are feasible.
NOTES
The required input maps are the ones with the segments of the potential plants (vector), the structure of these potential plants (vector), the electric grid (vector), the landuse (raster) and the slope (raster).
In the section "input column", the column names in the table of the map with the potential plants have to be reported in order to read correctly the corresponding values.
Each section of the module calculates a cost. The used formula are valid for all the currencies but the values have to be adapted. The default values related to a cost are considered in Euro.
First, we define the total cost which is the sum of all the fixed costs corresponding to the construction and the implementation of the plant. It includes:
Compensation cost
This cost represents the value to compensate land owners in case of plants components implementation according to current Italian legislation. It is calculated with this formula:
where Lv is a raster map with the land use value
[currency/ha];
Tr is a raster map with the tributes [currency/ha];
Vu is a raster map with the value upper part of the soil
[currency/ha];
r is a scalar with the interest rate (default value: 0.03);
n is the life of a hydropower plant [year] (default value: 30);
γ is a scalar (default value: 5/4);
we is a scalar with the average width excavation [m]
(default value: 2);
res is a scalar with the raster resolution
The Vu raster map is computed with the formula:
where Sv is a raster map with the stumpage value
[currency/ha];
Rot is a raster map with the value rotation period per land use
type [year];
Y is a raster map with the average year [year]
The user can directly add the maps Lv, Tr, Sv, Rot and Y as inputs. Otherwise, the maps can be computed using the land use raster map and reclassifying the values with the module r.reclass. The program creates the reclassified maps if the user provides the input text files for each category (the input data is the path of the text file). Here is an example of a text file to create the landvalue raster map, the costs are in currency/ha:
1 = 0 rocks, macerated, glaciers
2 = 0 urbanized areas, infrastructure
3 = 0 shores
4 = 0 waters
5 = 200 gardens
6 = 4000 mining areas
7 = 2000 agricultural areas
8 = 1500 meadows
9 = 1000 areas with predominantly pastoral value
10 = 3000 forestry land
Once the calculation is made, a new column with the compensation cost is added in the table of the input map with potential plants. A raster map with the compensation cost can also be computed, as well as a raster map with the value upper part of the soil (see Optional section).
Excavation cost
This cost concerns the works of digging to implement channels. It is calculated as followed:
where S is a raster map with the slope in [%];
Ψ is a raster map with values of minimum excavation costs
[currency/mc];
Φ is a raster map with values of maximum excavation costs
[currency/mc];
w is the width of the excavation [m] (default value: 2);
d is the depth of the excavation [m] (default value: 2);
l is the length of the excavation [m] which depends on the
channels lengths
If the user hasn't got the raster maps Ψ and Φ, the latter can be computed from the land use raster map if the user provides a text file with the reclassification values (from land use value to excavation cost (min or max)). It is the same principle as the one explained above for landvalue, tributes, stumpage, rotation period per land use type and average age.
The user can choose to put a slope limit (Slim) [%] above which the cost will be equal to the maximum cost.
Then, a new column with the excavation cost is added in the table of the input map with potential plants. A raster map with excavation cost can also be computed (see Optional section).
It is the cost of the electro-mechanical equipment which includes the turbine, the alternator and the regulator. It is a high percentage of a small hydropower plant budget (around 30% and 40% of the total sum).
We use the Aggidis et al. formula which calculates this cost thanks to the values of power and head:
CEM = γ * powerα * headβ + c
where power is the power of the plant [kW];
head is the head of the plant [m];
α is a power coefficient (default value: 0.56);
β is a head coefficient (default value: -0.112);
γ is a coefficient (default value: 15600);
c is a constant (default value: 0)
A new column with the electro-mechanical costs is added in the table of the input map with potential plants.
Supply and installation cost for pipeline and electroline
This is the sum of the supply and installation costs for the derivation channel, the penstock (both compose the pipeline) and the electroline which links the transformer near the turbine to the existing grid. The formula is the following:
where α is the supply and installation costs [currency/m] (default
value for pipeline: 310 Euro/m, and for the electroline 250
Euro/m);
l is the length of the line [m], the pipeline length is found in
the structure map and the electroline length is computed thanks to
the grid vector map
Power station cost
It concerns the construction cost of the building composing the power station. It is considered as a percentage of the electro-mechanical cost:
CST = α * CEM
where α is as default 0.52
Inlet cost
It concerns the construction cost of the water intake structure. It is considered as a percentage of the electro-mechanical cost:
CIN = α *EM
where α is as default 0.38
All these costs define the Total cost:
Total cost = (CCM+CL+CEX+CEM+CST+CIN+CGRD)(1+α+β)
where CCM is the [currency];
CL is the Supply and installation cost for pipeline and electroline
[currency];
CEX is the Excavation cost [currency];
CEM is the Electro-mechanical cost [currency];
CST is the Power station cost [currency];
CIN is the Inlet cost [currency];
CGRD is the Grid connection cost, (default is 50000 Euro), that
includes the easement indemnity;
α is the factor to consider general expenses (default is 0.15);
β is the factor to consider hindrances expenses (default is 0.10)
α and β are factors which offset the underestimation of this total cost. Indeed, some other costs have to be taken into consideration but it's hard to make a general assessment because they are specific for each plant. Moreover, for each plant realization there are unexpected events (hindrances) which make the implementation more complex and expensive.
Then, the module calculates the maintenance cost per year, according to this formula :
maintenance = α * power1+β + c
α is a power coefficient (default value: 3871.2);
β is a power coefficient (default value: 0.45);
The yearly revenue corresponds to the money gained selling all the electricity the plant produces in a year. It is simply calculated as the product of the power produced in a year by the price of the electricity (including some coefficients):
revenue = η * power * price * yh * α + c
where η is the efficiency of the electro-mechanical components
(default value: 0.81);
power is the installed power of the plant [kW];
price is the energy price [currency/kW] (default value: 0.09
Euro/kW);
yh is the yearly operation hours of the plant [hours] (default
value: 6500);
α is the coefficient to transform installed power to mean power
(default value: 0.5);
Finally, all these values allow to calculate the Net Present Value (NPV). It is the sum of the present values of incoming and outgoing cash flows over a period of time. It allows to know if there are profits so if the plant is feasible. It corresponds to:
where revenue is the yearly revenue value [currency/year];
maintenance is the yearly maintenance value [currency/year];
Total cost is the total cost of the plant [currency];
n the number of years of the plant [year] (default value: 30);
γ is a coefficient which assesses the cost of interest and
amortization. It is defined as:
where r is the interest rate (default value: 0.03)
More concretely, the program computes the following results:
the input map with the structure of the plants has an updated table with the different costs of construction and implementation and their sum (tot_cost)
the created output map shows the structure of the potential plants with a re-organized table. The latter doesn't make the difference between derivation channel and penstock. Each line gives the intake_id, plant_id, side (structures are computed on both sides of the river), power (kW), gross_head (m), discharge (m3/s), tot_cost (total cost for construction and implementation), yearly maintenance cost, yearly revenue, net present value (NPV) and max_NPV. The structure of potential plants is given for each side of the river, max_NPV is 'yes' for the side with the highest NPV and 'no' for the other side.
the input map with the segments of the plants has an updated table with the total cost, yearly maintenance cost, yearly revenue and the net present value. The parameter "segment_basename" (in input column) allows to add a prefix at the column names in order to show the results for different cases in the same table without overwriting the columns.
in the Optional section, there is the possibility to create three raster maps showing the compensation, excavation and upper part of the soil values
EXAMPLE
This example is based on the case-study of Gesso and Vermenagna valleys in the Natural Park of the Maritime Alps, Piedmont, Italy.
Here in black you can see the input vector file techplants with the structure of the potential plants and the technical value of power (including head losses and efficiencies, computed by r.green.hydro.technical) computed by r.green.hydro.technical. The vector map with the segments of the river potentialplants is also visible in blue in this picture, as well as the vector map with the intakes and restitutions of the plants (in red).
The following command updates the table of structplants and segplants adding the costs:
Notes:
The rules files for the reclassification needed for the following
command can be created as shown in the section NOTES above for the
rules_landvalue.
To create the other rule files this link might be helpful:
r.category
The file techplants (input vector map with the structure of the plants)
has to be created for example by r.green.hydro.technical before entering
the following code.
plant=potentialplants
struct=techplants
struct_column_head=net_head
landuse=landuse
rules_landvalue=/pathtothefile/landvalue.rules
rules_tributes=/pathtothefile/tributes.rules
rules_stumpage=/pathtothefile/stumpage.rules
rules_rotation=/pathtothefile/rotation.rules
rules_age=/pathtothefile/age.rules
slope=slope
rules_min_exc=/pathtothefile/excmin.rules
rules_max_exc=/pathtothefile/excmax.rules
electro=grid
output_struct=ecoplants
compensation=comp
excavation=exc
upper=upper
It also creates four new raster maps (ecoplants, comp, exc and upper):
- ecoplants which shows the structure of the potential plants. The table contains these four columns (total cost, maintenance cost, revenue and NPV):
table of the output raster map ecoplants
The same columns are added for the input map with the segments (potentialplants). In the table of the input map with the structure (techplants), the different costs which compose the total cost are added in columns (but not the four previous values).
- comp which shows the compensation values (in currency) for each land use:
output raster map with compensation values
upper which shows the values of the upper part of the soil (in currency) for each land use
exc which shows the excavation value (in currency) for each land use
These two last maps look like comp, but with their corresponding values.
SEE ALSO
r.green.hydro.discharge
r.green.hydro.delplants
r.green.hydro.theoretical
r.green.hydro.optimal
r.green.hydro.recommended
r.green.hydro.structure
REFERENCE
The costs of small-scale hydro power production: Impact on the development of existing potential, p.2635, Aggidis et Al, 2010
Text on expropriation for public utility D.P.R. n. 327/2001, updated in 2013
The excavation costs are found in the price list of the Piedmont Region for public works
The costs of intake and civil works are based on analysis of technical documents for mini-hydro projects in Italy
The calculation of the yearly maintenance cost is based on the report AEEG for the Polytechnic University of Milan
AUTHORS
Pietro Zambelli (Eurac Research, Bolzano, Italy), Sandro Sacchelli (University of Florence, Italy), manual written by Julie Gros.
SOURCE CODE
Available at: r.green.hydro.financial source code
(history)
Latest change: Thursday Mar 20 21:36:57 2025 in commit 7286ecf
